Sky InsuranceAH Fabrications
    Jul 2011
    what to look out for?
    Been reading through lots of threads for various things to check on these cars, been to see a few A3's and test drove them.
    With my budget the A4 is now looking like a better option as you do get alot more car for your money! Going to look / test drive one o weds, 55 plate, 140 S-line on 91k, FASH. Been advised to watch out for the flywheel / clutch, do they suffer with similar problems with the aircon fans or cyclinder head issues?
    Any advise would be great
    Jul 2011
    72
    check the engine code, it will be on the log book/chassis number or even the hpi check will have it, avoid it if the the code start with BLB as thay have oil pump problems, thay are driven on a chain were as the chain can fail and cause a mega expense. this issue only seems to be on the 2005 models were as audi chainged it in 2006
    Jul 2011
    Cheers dude will check that out!
    *edit*
    The engine code is BRE
