Volks AutosSky Insurance
Results 1 to 10 of 10
    Jun 2011
    6
    Auto close windows
    Hi All,
    im after some advice, now my A4 had the auto shut windows where if you held the lock button they would close.
    Now after the car has been in for some indi warranty work they fail to do this operation.
    The garage have said this would not have been from them disconnecting the battery.
    Any ideas on what has happened? are they right?
    Cheers Mike
    Shark in a Goldfishes clothing
    Nov 2010
    Nottingham
    576
    Does the one touch window operation work?
    If not it maybe that you have to set them first?
    Maybe a daft question but do they open when you hold the unlock button down?
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Quote Originally Posted by Sock View Post
    How do you do that ?
    Nov 2010
    Nottingham
    576
    Starting with the windows up:
    Push the button till the window is fully down then release for a second and then press again and hold for about 4 seconds, then send the window all the way back up and then release again and the hold for another 4 seconds. that should re set the one touch settings so they come down on there own. after you have done all the windows try holding the unlock button and see if the all come down?
    Nov 2010
    Nottingham
    576
    Any joy mate?
    Jun 2011
    6
    Hi thank for the replys,
    The one touch still works, and I only ever had the close setting.
    i will give the rest a go and see what happens.
    Cheers Mike
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Quote Originally Posted by macpdm View Post
    By reading the manual?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jun 2011
    6
    Well thanks guys i reset the windows and now have the function back.
    cheers Mike
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,243
    Thanks sock, sorted mine after changing the battery and losing the function
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Nov 2010
    Nottingham
    576
    Lol think that is the first time since I joined that I was actually able to help someone else for a change
