Chris NottVolks Autos
Results 1 to 7 of 7
    Aug 2010
    leicester
    Rain sensing wipers...
    Pain in the arse, I want the wipers on when I tell then!
    Anyone know how to stop them??
    Thanks, Richard
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Put the stalk down a notch?
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Jul 2010
    Kent
    175
    yup, put the stalk down one, or adjust the sensitivity with the scroll wheel thingy on the wiper stalk.
    Four Sprung Ducks
    Aug 2010
    leicester
    Tried that, it works when I scroll up then back down to over ride but after a few mins back doing it's own thing.
    Its not always a pain, just sometimes the wipers want to do 90 when it's only spotting, If I leave them they do slow down but not straight away.
    Didn't know if there was a way to over ride, maybe pull a fuse or something?
    26,719
    Could try decoding them if you dont want at all.
    Aug 2010
    leicester
    It may just need the sensor cleaning, any ideas where it is located or how it works?
    26,719
    Unlikely, its fixed to the screen behind the mirror fixing via a gel pad, detects taps on the windscreen, unless your mirror fixing is loose & moving the gel sensor/sensor itself.
