AH FabricationsSky Insurance
Results 1 to 7 of 7
    Mar 2011
    North Wales
    201
    Changing the oil
    Hi All,
    Think I might change the oil myself on 2007 2.0 tdi.
    Anyone know if I have to remove that whole plastic protection piece under the sump to get access to the sump nut ? Looks a bit awkward to do on the drive with a jack and a couple of axle stands
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    You have to undo all the quick release fasteners and take the cover off. I invested in a Pella pump, it sucks the oil through the dipstick hole, it saves loads of hassle.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    kev1000's Avatar
    Jun 2011
    County Cork, Ireland
    194
    do it, it's easy and afterwards you'll feel better for doing it yourself.
    a little tip for you : if the oil filter is a bit too tight to open by hand and you don't have a special tool for opening it, wrap a piece of sandpaper around filter ( grit against filter) and twist.
    always works for me anyway.
    Mar 2011
    North Wales
    201
    Many thanks - I'll investigate the pella pump option too.
    Car has only done 4k in the last 12 months ( last oil change ) - would you guys still change the oil ?
    Mar 2011
    North Wales
    201
    stupid question but ( when facing the front of the car ) where is the sump plug ? , struggling to get tunder the car, not enough room
    Wish I'd bought the pella pump
    Mar 2011
    North Wales
    201
    Question
    Quote Originally Posted by mm707 View Post
    Also - do I remove two plastic trays from underneath or just the one nearest the back ?
    kev1000's Avatar
    Jun 2011
    194
    Front tray will do.
    Can't remember which side the sump nut is. feel around the sump for it.
    It's Probably a 14mm or a 17mm.
