AH FabricationsChris Nott
Results 1 to 16 of 16
Thread: SMOKEY AVANT
    Jun 2011
    6
    SMOKEY AVANT
    Hi, I have a 3.0tdi B7 avant. The problem is that after it warms up it belches black smoke when idiling or moving slowly in a line of traffic. When the car is driven normally it doesnt happen as I've driven behind it to check. Can any of you boffins advise me please.
    Cheers.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    patches !
    Jun 2011
    6
    Cheers mate, see this forum is just like the rest.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,906
    It might be the PCV valve, it diverts crankcase fumes to the inlet. Give it a clean.
    *Note, this is what it was on my V6 Cosworth, it might be the same*
    JSD 2.59
    Synergy-Solutions
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    1,906
    A quick google found this, it might give you some pointers, if not, it will at least explain how its caused which may help you to determine whats up.
    Diesel Smoke tells YOU a Story
    JSD 2.59
    Synergy-Solutions
    bez101's Avatar
    Jul 2008
    7,910
    Quote Originally Posted by banjo69 View Post
    same as the rest in you should have a search 1st
    i did and got quite a few results
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Hi mate, don't confuse someone having a bit of humour with not being helpful. Bez101 has come up with some good info and advice in the past that's helped other members. It's just that there seems to be a lot of repetitive questions at the minute as people aren't searching previous threads or the Internet (I dont necessarily mean you). Maybe that frustration comes out in some replies.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Jun 2011
    6
    Thanks for the advice lads, much appreciated. As I am new to the forum and havent had a lot of time to spare a quick search didnt throw up any pointers so that is why I put a new post on. As I was worried that something major might be wrong I didnt see the funny side of bez's reply. Apologies if I was a bit sharp but I've come across too many smart arses on other forums who offer no worthwhile suggestions to a question but only post to make light of someone elses problems.
    Cheers.
    bez101's Avatar
    Jul 2008
    7,910
    try audizine you would love the info on there
    and on here a good sense of humor goes a long way
    brokensprung burke unteknik
    Jun 2011
    16
    hi buddy, you prob find its a faulty egr valve(exhaust gas recirculation valve) had same on mine. try some unipart egr cleaner and a good hi revving run after...should clean it out if its not damaged...sometimes it gets gummed up and bends the butterfly..
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    It's 1 or more injectors. ££££
    A close friend of mine had the exact same thing on his 3.0 tdi. You got a warranty?
    Jun 2011
    6
    Thanks for all your help lads its much appreciated and apologies once again to Bez.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Did you find out what it was?
    RNS-E retrofitted
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Cheers.
    Fortunately for you aythreee has not replied yet.
    Try adding 300ml of 2 stroke part synthetic oil to your fill up, will allow the fuel to burn cleaner and clean out your engine.
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    Jun 2011
    6
    Going to clean the egr over the weekend and also try the oil/fuel mix as someone else told me about it.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    If you do a write up of how the EGR clean goes, where it is and any tips, it would be appreciated.
    RNS-E retrofitted
