Volks AutosBadger5
Thread: AirCon Hiss
    74
    AirCon Hiss
    Ive had my head under the bonnet today, and found a strange hiss coming from around the high and low pipes on the air con, it seems to be coming from where the two pipes go through the the engine compartment into what i would class as the top compartment of the engine bay where the round drum is (speedo) i think i could be totally wrong with that description. the pipes go through the panel and have a rubber sleeve round them its above the topup valves. only hear a hiss there, is this normal? i cant feel anything and the pipes defiantly get cold with condensation appearing on. the system was refilled and dye added also cant see any dye around that area.
    lespaul's Avatar
    Dec 2010
    Oxfordshire
    59
    Mine does it and I notice it after I have turned off the engine. Normal I'd say son
    2.0 TDI 170 S-line SE
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Mine does this and I asked the AC engineer and he said its normal.
    Its something to do with the gases equalizing.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I've looked on ETKA and it's a small snake called Marvin that lives in the tubes. He doesn't like getting too cold so lets off excess gas once in a while.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    74
    thanks guys, thats a relief i was starting to think there was aircon issues..
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    i like the marvin guess
