AH FabricationsVolks Autos
    Cribbon's Avatar
    Jun 2011
    Hainault Essex
    154
    help bose sub rattle rear shelf
    hi all i have an audi a4 saloon with the bose audio love it to bits, have notice that the bass vibrates the rear shelf and has a rattling sound, if i push gently on it it stops has anyone had this issue and if so how have you stopped it!
    si hoc's Avatar
    Jan 2011
    middlesbrough
    108
    have you tried retightening any of the fittings ??, they might have rattled loose, ive got bose in my avant and the sub is in the back right hand side behind the panel, and when ive got it loud the fuel filler cap vibrates!!!, cant rate the bose high enough
    07 a4 2.0tdi s line avant
    Jul 2010
    Kent
    175
    On the salloon the sub is mounted below the parcel shelf mate, haven't found a solution yet but mine appears to do this too, although it could just be a design flaw.
    Four Sprung Ducks
    Cribbon's Avatar
    Jun 2011
    Hainault Essex
    154
    yeah ive tried tightening the fixings! i have some spare foam padding laying around and was thinking of putting few lines of that in if i can remove panel but going to have to see if possible when next got day off!
