Sky InsuranceJMB Retrofits
    Jun 2007
    131
    What part is missing?
    Hi
    Just opened the passenger door on my A4 B7 cab and on the edge(above the locking mechanism) theres a round hole (about 2 cm diam). I'm assuming some sort of reflector for when the door is opened. Any ideas please.
    Ta
    JohnyT
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    post a pic
    its not a reflector not on mine anyway
    prob a cap covering a access hole
    Jun 2011
    Shrops / Wilts / Oxfordshire
    On mine I have a hole where you can lock the door manually if the central locking fails. When you look into it there is a yellow key turn barrel. I also have the cover missing. hope this helps.
    GS
    2006 A4 S Line Cabriolet. I'm a pervert, it's a Diesel.
    North Wales
    39
    Just been out to check mine and I have a round cover with a picture of a lock on it and a small horizontal hole big enough to fit the ignition key through.
