Monster MotorsportBadger5
Results 1 to 9 of 9
    74
    B7 A4 2.0TDI Service
    Hi Guys, service is due and im thinking of doing it myself as its the 40k service its been serviced all round by audi before and if its just the usual filters and oil, id prefer to save the money thank shell out for an audi monkey at the stealers..
    my question is what oil are you all using ? Castrol SLX Longlife 3? is there anything else required at a 40k other than usual filters etc.
    it had brake oil change last service so should be ok on that.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Castrol edge.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    Trans oil if its an auto.
    JSD 2.59
    Synergy-Solutions
    jfarhead's Avatar
    176
    Make sure the engine oil is VW 507.00 if your engine type needs it (DPF), don't know if the Castrol Edge comes in 506.xx so mentioning it just in case.
    Report to VOSA:
    www.dft.gov.uk/vosa/onlineservices/vehicledefects.htm
    You are covered by the Sale of Goods Act 1979:
    • Goods must "conform to contract", without an error in manufacturing where a faulty component was inserted
    • The seller is responsible for up to six years after purchase
    Facebook:
    http://www.facebook.com/pages/Fix-th...56033921135623
    74
    Thanks Everyone - jfarhead.. i have a 2.0tdi with DPF, so thankyou for your advice i im sure that audi gave me the 5w40 castrol long life stuff before as the topup oil, but never used it, ive never had to topup oil between services and i dont drive her steady in a long shot..
    ill see if i can find any of that oil you mentioned.
    thanks again
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Castrol edge is the correct spec and readily available in Halfrauds or online. They have it cheap in Costco if you have a card.
    RNS-E retrofitted
    Mar 2011
    North Wales
    207
    castrol edge 35 quid in asda for 4 litres and it is vw 507.00 so will be ok
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Check which one it is though as certain ones (I think it's 5w-40) should only be used on fixed service intervals. As you're servicing it yourself, I'm sure you'll be on fixed interval anyway. All the info is in the owners manual.
    RNS-E retrofitted
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Would have thought it would be a 5W,30 same as my 3.0 DPF but not sure
    Anyway its definatly Castrol Edge you want!
    If you just buy your own oil and take it too audi it will cost you half as much to have it serviced with them, and you will still get the stamp etc. (if thats what you want)
    Or take it to the guys at VAGTECH who do a damn better job than audi at a fraction of the cost!
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
