Sky InsuranceEM Tuning
    May 2011
    Glasgow Area-ish
    62
    2.0 TFSI Won't start
    Ok so the car ran fine 2 weeks ago when I parked it up to go on holiday, I got back and it won't start.
    Checked and the top of one coil pack was swollen and out of place, very odd so I changed the coils (model A to F) and the plugs (ngk to bosch). Still no joy.
    Checked and the ecu fuse along with the rest are ok.
    But still the car just turns over but refuses to start, any ideas??
    VCDS & TPS Account holder.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    get it scanned for fault codes
    could be the crank sensor
    or a few other things hard to guess and could cost loads with out a scan
    May 2011
    Glasgow Area-ish
    62
    Sorted now I realised there was another ECU surge fuse (25a) under the ECU in addition to the ECU fuse in the box.
    Was a mission getting the ecu cover off as the wiper arm on that side is stuck solid but some fiddling got that bolt in that corner of the cover the rest was sliding and twisting of the cover while moving the ECU to get it in /out. Fiddly but possible.
