Monster MotorsportVolks Autos
Results 1 to 8 of 8
    oneniner's Avatar
    Nov 2004
    UK - Midlands
    42
    Is there a guide to change steering wheel?
    Can someone advise me how to change the steering wheel on a B7 chassis. Both steering wheels are exactly the same, but the one I am fitting has the S Line logo. So both are multifunction. Will I still need Vag Com?
    Audi B7 Tdi Avant and B7 Cab
    1,877
    No, vag-com is not require, but good practice to clear & check for fault codes. It's a simple task undo the allen key bolts ( 6 or 8mm cannot remember) once removed unclip the air bag. There is one big splined bolt to remove ( this should be replace as thread lock is used) fit new steering wheel and secure bolt refit air bag.
    I always disconnect the battery before removing the air bag, as the way I see it you don't the thing going off in your face if something goes wrong (most people don't bother, it's up to you on that one)
    oneniner's Avatar
    Nov 2004
    UK - Midlands
    42
    So if I just unplug the connectors and plug it into new steering wheel.. Everything will work as it should? Volume, track selection etc..
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    if there both the same yes they will work
    oneniner's Avatar
    Nov 2004
    UK - Midlands
    42
    Thanks all.
    oneniner's Avatar
    Nov 2004
    UK - Midlands
    42
    I cant seem to locate the Allen key bolts. Are they underneath the front cover? If so do I just gently pride it off?
    1,877
    either side behind the steering wheel you see a half moon clips you need to remove them to see the allen key bolts.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    There on the rear of the steering wheel.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
