EM TuningAH Fabrications
Results 1 to 7 of 7
    Jun 2006
    135
    Guide for changing springs only on a B7
    Hiya all,
    I have had a good search around and have not found what I am looking for.
    Is there a DIY guide anywhere that covers the process for installing front and rear lowering springs on a B7?
    Rears seem simple enough, its the front I am most concerned with.
    Thanks in advance.
    Dale
    Audi A5 2.0TFSI 211 S Line
    Lotus Evora
    unikarl's Avatar
    Mar 2004
    374
    I used this.... Just disregard the parts your not bothered about as this guy fitted coilovers.
    Right PITA of a job to be honest!
    :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
    2.0 TDI S line.
    Cruise, Leather, DIS, RNS-E, autodim, MFSW, ambient lights, Bi xenons.
    Gone to its new home
    Jun 2006
    135
    Is it? Dealers said its about a 2 hour job so thought worst case 3 - 4 hours.
    I think the fronts would be most difficult.
    How long did it take you?
    Lotus Evora
    unikarl's Avatar
    Mar 2004
    374
    All day!
    The bolt that hold the upper ball joints into place siezes itself on so that's very time consuming. The rears are in so tight its untrue and you can't get spring compressors in as there isn't enough room so you have to drop the subframe and pull like hell on the arm while prizing the spring out..
    If the dealer can do it in two hours and that's all they will charge you for it then that's a good deal.
    2.0 TDI S line.
    Jun 2006
    135
    Hmm, I still think I might give it a go tomorrow, car is only a year old so hopefully not to seized up.
    Worst comes to the worst I just do it back up and book it into the dealers.
    Oh when the instructions say to apply load, I assume just pop the jack under the disc and jack it up to put some pressure on the shock to simulate the cars weight being on it?
    Lotus Evora
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    A year old?? Are you in the right section mate?
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Apr 2011
    197
    if the upper arm bolt is seized just remove the full leg (dont hit the bolt with a hammer as it will swell inside the bearing carrier and cause you a nightmare)
    the rear can be done with the correct spring compressor in situ
    also you need a full 4 wheel align after to rest tow, bump steer and camber for the front and rear
    all in with 4 wheel around 8 hours
