Kufatec harness with oem bluetooth and rns-e
phil_w
Gold Supporter
Nr Scarborough
Just bought KUFATEC GmbH & Co. KG - Kabelsatz Handyvorbeitung Audi - "Nur Bluetooth" Plug & Play 37881
Stupidly i put the car back together without fully testing. Rns-e and oem bluetooth get on together ok and dial in and out. However bluetooth is not visible on vcds on channel 77 so i suspect its a k- line issue. I read about kufatec Cables either having k-line missing or swapped with telemute. Anyone got any experience with the 'plug and play harness' so i know exactly what i'm looking for when iremove the glovebox again?
Took it all apart again and lo and behold no k-line - so much for plug'n'play
Well at least you found the problem to be a simple one. Ive just installed rns to my car and wouldndt be too pleased if I'd have had to take it all back out again though!
