AH FabricationsSky Insurance
    Jun 2010
    South Wales
    69
    Turbo intermitently kicking in. 2.0tdi
    I recently washed my car to get all the crap off my car with a power washer and when I used my car today the turbo seems to only kick in intermitently. I did'nt jet wash the engine and the lower engine cover was on. Then the engine management light has also now come.
    Any ideas...
    Jun 2010
    South Wales
    69
    Have now been told its the EGR valve. What is involved with changing this and will it need resetting after being refitted.
    Nogwuy's Avatar
    Apr 2007
    Suffolk
    85
    egr valve relitivly easy to fit, (had this go on mine where the exhaust part cracked causing turbo to stop functioning meaning very low power and loud blowing sound. i thought it was the ballance shaft problem at the time but actually replaced all that gubbins as well after finding out it was the egr!! much easier than doing that lot!) all accesable from lifting the bonnet. you will have to drain the coolant and remove air box etc for access. but not too bad as i seem to remember, (and you will need some torx bits sockets).
    wie sind ein volk!
    Nogwuy's Avatar
    Apr 2007
    Suffolk
    85
    no re-setting required as i seem to remember, just replace the coolant and it should be ok. there was no damage to my turbo.
    wie sind ein volk!
