AH FabricationsChris Nott
    May 2008
    66
    OEM Xenon Headlamp Conversion - Part Numbers
    Hello,
    I want to convert my headlamps to Xenon lamps with the integrated round DRL lamps (as per the RS4). I am aware that factory models also head a headlamp was system, but at this point I was wondering if anyone could help me with the necessary part numbers and a list of items required.
    Headlamps
    Ballasts
    - Different wiring loom?
    Any other physical parts required before making the changes on VAG COM?
    Many thanks!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,489
    headlights
    ballasts
    bulbs
    loom
    vcds
    Oct 2005
    london
    24
    Pretty much the above is needed.
    I have a pair of complete xenon headlights if your interested. Ballasts, bulbs and all included.
    Drop me a PM
    May 2008
    66
    Thanks Yaz - although I'm looking for clear rather then tango ones
    Are the headlights with the DRL's like the RS4 bi-xenon? If so they're also adaptive and stuff, right?
    So there are two different types of Xenon headlamps to look out for?
    Can anyone help?
    Cheers,
    A
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    I did the upgrade - your best bet is to wait for some to come up on eBay - they're very expensive from Audi. I'd let you know the part numbers, but they're hidden now the lights are in the car.
    You'll need a PC laptop with VAG-COM installed, a suitable serial cable, the lights/ballasts/ignitors/etc. and a wiring harness. Kufatec do two versions - I went for the cheaper one that doesn't add auto-levelling.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
