Badger5Sky Insurance
Results 1 to 18 of 18
    mikeyw's Avatar
    Jan 2011
    135
    2.0T needs new brakes
    I have a 2007 2.0T Quattro S-Line SE that needs new discs and pads. I'm having a little bit of trouble trying to find the right bit's I need.
    Are the disc's 321mm front and 288mm rear?
    Are pads the same on all 2.0T or are the special edition ones different?
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    discsare defo 321mm up front if it a special edition not sure on pads tho
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    solaris's Avatar
    Slough, Berkshire
    404
    Quote Originally Posted by mikeyw View Post
    Correct 321 Front 288 Rear
    Front pads are all the same AFAIK (Part 8E0698151C)
    What setup are you thinking of going for?
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    mikeyw's Avatar
    Jan 2011
    135
    Quote Originally Posted by solaris View Post
    I was maybe going to try the M-tech discs. I've had EBC stuff before and I didn't like it. I was also just going to contact Audi and see what they'd charge, because they supposedly have a fixed rate of £249 for front and back.
    mikeyw's Avatar
    Jan 2011
    135
    Another question....
    Is there a brake pad/disc warning indicator? I guess there is, but is is audible or a dash light?
    25
    I had my front pads done on my 2.0T S-Line SE at Audi about two months ago. They do fall within the Fixed Rate, but they weren't too happy about it .
    I was told by a independent garage that I needed front discs as well but funny enough Audi said not.
    I got a warning symbol come up on the DIS (with a boing), but apparently (according to Audi) only the front give a warning, I don't know if this is true but I'm sure someone else on here can confirm/deny.
    2006 B7 A4 Avant S-Line Special Edition 2.0T Moro Blue
    Jun 2010
    Manchester
    23
    Quote Originally Posted by suckedin View Post
    The discs can have 2mm of wear (something like 25mm max to 23mm min on front discs) before they should be replaced - you have to put new pads on at same time as new discs but not vice-versa.
    The front pads have wear sensor in them - you have to disconnect it when swapping. The rear pads have no such trickery...probably because they dont get nearly as much wear as you dont rely on them to stop as much.
    A4 2.0TDi S-Line 170(Remap) 6 speed Manual
    2011 plan | B5 spring cups | RS4 RARB | 17">19" | Connect ipod
    solaris's Avatar
    Slough, Berkshire
    404
    This is exactly what I was going to do as it works out more expensive to buy the discs from Audi and fit your self. I too am not a fan of EBC let me know how you get on with M-tech.
    I chose Hawk HPS pads along with ECS Tuning discs. I needed a better compound low dusting pad and the Hawks fit the bill.
    Jul 2010
    Kent
    175
    So minimum disc thickness is 23mm? Hope so as mine are at 28mm and Audi advised I replace them.....lol
    Four Sprung Ducks
    Jun 2010
    Manchester
    23
    Depends on your car what thickness your discs should be..2mm wear (from new) is probably standard though.
    Jul 2010
    Kent
    175
    It's a 2.0T SE matey, same as the original posters. Was considering going RS4 all round, but don't have the fundage to do so right now.
    Four Sprung Ducks
    Jun 2010
    Manchester
    23
    ..then those are big, eff off 30mm discs...28mm minimum sounds right...must weigh a tonne.
    Jul 2010
    Kent
    175
    looks like I might have to call in then under the fixed scheme lol, be buggered if I'm paying the prices they want over the stores counter!
    Four Sprung Ducks
    Jun 2010
    Manchester
    23
    Try GSF for the parts GSF | Cheap Discount Car Parts | Euro German Japanese | VW BMW Audi Ford Peugeot and see what a local garage would charge to install?
    I got Brembo front discs for about £25 each - the 30mms are a bit bigger admittedly so may be a little more
    Jul 2010
    Kent
    175
    Audi want nigh on £500 for a pair of discs, as they're drilled, but will give GSF a go, thanks
    Don't mind installing them myself, it was just looking cheaper to go for the £249 fixed audi plan rather than buy the parts seperately and do the job myself lol.
    Four Sprung Ducks
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    £500 ouch! I have the same car, as you say there must be a better option.
    Jun 2010
    67
    Just ordered my full Mtec set up yest but gettin my summer wheels redone at the min so will prob be a few wks before I get them all fitted, went for the black editions.
    Jul 2010
    Kent
    175
    Quote from audi for the lot on 2/10/2010 for 320x30mm front discs, 288x12mm rear discs and pads to suit all round came to 478.37 including VAT, that was over the parts counter.
    Took it in for a service and got an advisory on the front discs and pads all round, because the pads are half worn lol....and they wanted £502.34 for the front discs, £227.21 for the front pads and £181.24 for the rear pads all fitted, comes to a staggering £910.74.
    Not bad *cough* considering they will do front or rear discs and pads for a fixed price of £249 fitted. Doing so means I can get away with spending the £249 for the front discs and pads, then buy the rear pads over the parts counter for around £35 - £40 and fit them myself to spend a total of at most £289, plus any tool necessary to wind back the ABS.
    Four Sprung Ducks
