Badger5AH Fabrications
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    Warning - Bad Repairs at Audi Sinclair Bridgend South Wales - Copy
    hey all please be aware of this i dont want anyone going through what ive gone through
    Any Mods/Admin anychance this could be made sticky in certain forums i will post it in few to create as much awareness as possible
    here we go....
    Bare with me a bit this is long but its needs to be sorry
    Ok as some of you know from my previous thread my beloved A4 was hit by some inconsiderate so n so who didn’t care that I spent 6 hours the day before polishing it!
    And then I was then faced with every OCD’s worst nightmare
    Where to take my beloved car for the repair’s as I was not at fault I had the choice and chose to take it to Bridgend Audi being the closest main dealer to me. On arrival at the body shop first impressions was good very professional and organised.
    However the repairs did not support their professional look. Upon receipt of the car I found a host of problems which were:
    Ø Poorly fitted window trim
    Ø Front door does not close as smoothly as before
    Ø Front seatbelt ratchet mechanism was noisy not smooth as it should be
    Ø Brushed aluminium trim inside was cleaned with chemical which left milky residue on surface (not sure if its damaged them as I had to leave it alone until it was reported to them)
    Ø Starches on Bonnet, Roof and Boot were tools/parts had been put down on them
    Ø Cutting/polishing compound splattered over scuttle panel under windscreen and left in panel gaps
    NOW FOR PAINT ISSUES
    Ø Burnishing marks were left from the buffing/mopping process
    Ø Orange peal
    Ø Paint was far too thin (found this out after the above issues made me investigate further)
    Upon finding these problems I immediately got in contact with my local detailers to give the car a full inspection.
    The detailers in question were Colin & Grant of PRD – Perfect Reflection Detailing
    Upon the inspection they found all the problems listed above and then proceeded to check the depth of the paint while doing this they were shocked with the results the reading were in the low 80’s and 90’s for those who don’t know healthy paint should be well over 100 microns! The rest of the car was reading from 110 up to & over 200! When I took it back to the body shop he took his own readings with the industry approved meter and the reading ranged from low 60’s to low 90’s.
    PRD then submitted a full report which I then produced to the body shop that didn’t seem at all concerned and said the paint was fine, I told him that two experts have stated in writing that it wasn’t and the average reading across the repaired panel work was far too thin and unacceptable and I would like it re-painted to co inside with the reading on the original paint at least. He said they weren’t prepared to it as it would cost then too much.
    It was at this point I contacted Audi UK to lodge a complaint and find out their industry standards were with regards to paint depth. In all fairness the guy I first spoke didn’t have a clue but got back with in 10min after speaking to a technical advisor, who advised him that Audi say the paint should be a minimum of 90 to 100 microns. He then opened the case and contacted Bridgend Audi to investigate the matter further. The body shop then contacted to say they were now willing to do the work highlighted above and would give me ring when a slot become free in the body shop. The slot they gave me was the Monday before Easter and said it would take four days (bit concerning considering the amount of work) I agreed to pick the car up the following Tuesday as I was away for the Easter weekend. When I went on Tuesday I was accompanied by Colin (PRD) and we were shocked and pretty disgusted with what we found the one good thing was the paint was 100% better than before and was showing pretty good clean reflections. But the good work was not the case for the rest of the car! The new list of problems was now:-
    ¨ 2 new dents on front wing (free of charge)
    ¨ Over-spray on inner of back door
    ¨ Front door card was not fitted correctly and the window rubber had been twisted as a result
    ¨ Rear window seal was still miss-shaped (this was supposedly new)
    ¨ Surface scratches in paint from using incorrect drying technique (I did tell them not to wipe the car with anything jus hose/jet-wash the worst of it off)
    ¨ Paint run on the start of the back arch
    As a result I left the car there and told them this was their last chance to sort the problems out if they didn’t I would be taking it to another body shop n sending them the bill! Funny enough the dents were done the same day even though they claim they were there before hand (not a chance!) a new rear rubber was ordered for the next day (rear rubber number 3!) the over-spray and the paint run would also be done they said by tomorrow and the front door card. Went down the following afternoon and all the problems were now done (yippee) although they had buffed the whole side of the car again n left holograms in the paint this time! At least this was nothing major and Colin and Grant (PRD) would remove these correctly for me. At this point I finally was able to drive my girl home not completely 100% perfect but it was close enough and the rest I’d sort out.
    Below are some pics of the accident damage and the body shop damage
    PLEASE ALL OF YOU TAKE NOTE IF YOU’RE EVER IN THIS SITUATION TAKE YOUR CAR TO SOMEONE YOU CAN TRUST AND HOPEFULLEY YOU WON’T HAVE THE SAME HEADACHES I HAD
    Also id like to add that this case would not have been solved to quickly (even though it was the best part of 2 n half months) without the help and support of Colin & Grant – Perfect Reflection Detailing! Perfect Reflection Detailing
    THANK YOU GUYS (also if there’s anything I missed out or you’d like to add please do)
    pics pre accidident (day before infact)
    ok accident damage now still painfull
    pics from when me and Colin went to inspect on the Tues
    thanks for taking the time to read hope none of you have to go through this
    reagards
    Darren
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    Mar 2011
    Dumfries and Galloway
    148
    If you had been someone who was clueless they would have got away with it, but thankfully you werent. These f***ers met their match this time ha
    drmole's Avatar
    Apr 2010
    1,564
    exactly my point average joe bloggs public would have rolled over n said ok if thas how it is thas how it is
    i would strongley recomend anyone who is not happy like i wasnt get the work checked by Professionals like i done with PRD without there report i would never have found out that the paint was very thin!
    thanks for your comment spread the word make life as awkward as possible for the b**tards
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    id not sigh that work off, get the MD down from his office and ask him why his dealership is putting crap work like that go on under his roof.
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Audi have fixed the trim,paint run,overspray . The pics show the ill fitting trim and over spray,dents on our 2nd visit . I spoke to the body shop manager on the phone once he had received our report and was going mental on the phone to me telling me there work was done to AUDI Standards ?? and the paint was applied to a correct standards. The first time Darren (drmole) asked us to look at it, we could not belive the poor workmanship. All is well now with the paint showing good healthy reading's with only minor correction required.
    AUDI A4 190T S-LINE.
    drmole's Avatar
    Apr 2010
    1,564
    yeah as Colin said its about 90% finished now gunna give it a good clean n polish 2moro n get some after pics up for u all to check out
