AH FabricationsSky Insurance
Results 1 to 17 of 17
    Mar 2011
    112
    Cruise Control Fitting - How easy to fit actual parts - advice needed
    Hi Guys
    Looking at fitting Cruise to my Avant. I am after some advice on how easy it is to fit the actual parts to the car i.e. removing the air bag and steering wheel and then fitting the stalk and cowl and refitting the airbag.
    I know that it will then require enabling with VCDS to get it to work.
    My car is fitted with the driver information stalk on the right hand side that shows tank range, mpg and various other information.
    Any advice will be useful.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    it takes less than an hour to fit the parts and thats takeing your time
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I'm sure someone will correct me if I'm wrong but if you don't have a multi-function steering wheel then you may need a new steering wheel control module as well.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    bez101's Avatar
    Jul 2008
    8,510
    Quote Originally Posted by Wrath View Post
    some have the correct swcm fitted most dont
    74
    if you have a multifunctions about steering wheel and DIS then its about 25 for the stalk and casing.. however if your not confident in removing the airbag and steering wheel then its not recommended, you do need to remove the steering wheel to add the stalk i cant remeber the exact number for the steering wheel control unit but if its not the right one its over 200 for the part
    other than that its a really easy fit, remove airbag, steering wheel, clip new stalk in and code away
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    25, are you sure about that!!!!!
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    The parts cost me nearer 100, 80 odd if I remember correctly.
    I have the mfsw so didn't need to worry about the steering wheel control module. There are loads of guides telling you what tools you need, the main 2 being M12 spline tool and a very small torx that is about 60 mm long.
    Chris
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    That's where ebay.de and Google translate make things cheaper
    Nathan
    si hoc's Avatar
    Jan 2011
    middlesbrough
    108
    awesome charge 299 + vat
    07 a4 2.0tdi s line avant
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    300 for cruise?! Jeez. It cost me 12 for a stalk and 20 for the cowling. Got a slip ring, indicator and washer stalk and SWCM for 80.
    Nathan
    74
    yep definatly only cost me 25 - stoke audi sorted me out, tho they were kinda confused about the stalk i needed but they came through..
    they wanted 199 to code it.. im sorry but just for one of there numpty technicians to plug a cable in and type a few your better off getting a vag-com cable i got a cheap $8 one from china and did the job with no problems..
    Mar 2011
    112
    Thanks Guys. I've priced the stalk and cowl at approx 50 from dealers.
    Has anybody had any issues with removing and installing the Airbag?
    Also, can anybody tell me how to code it once connected.
    Jun 2009
    Nottinghamshire
    184
    Custard do you have the part numbers for what you got ?? and which delaers did you get it from ?? that seems reasonable
    Funky
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Quote Originally Posted by Custardsucker View Post
    Just the cowl from Derby Audi was over 30. I didn't price the stalk as I already have one but I'm sure it'd be more than 20!!
    RNS-E retrofitted
    lespaul's Avatar
    Dec 2010
    Oxfordshire
    59
    anyone in oxfordshire able to to the whole job?
    Mar 2011
    112
    Funkycliff, I got the part numbers of my ETKA they are Stalk 4E0 953 521 B priced at 24.50 & Lower Cowl 8E0 953 512 P priced at 25.75
    These are the parts i think i need but haven't ordered them yet and can't guarantee they are correct. Will probably order later next week, so will be able to confirm then. They will come direct from TPS as I have a friend in the trade who gets all my parts, but I think these retail prices.
    Hope this helps.
    Mar 2011
    S E Kent
    238
    I too am tempted to getthis done on my B7 Cab.
    Already have the MF wheel and tiptronic
