Chris NottVolks Autos
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    hot air all the time even when on cold !
    got these fault codes on 56 plate avant.... 00710 01809 01810 heaters are blowing hot air all the time even when set to cold !
    Full leather/19"wheels/cruise/
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    I had this with one side of my car. I can't remember the code number but it's probably either one of the regulators has failed or the regulator arm is stuck (mine was stuck).
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    where is the regulator arm?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    I only had to undo the passenger side, I removed the glovebox and there are a set of regulator motors, two with green arms and one with an orange arm. I turned the air on and when you press various combinations, the motors all move. My temperature regulator (orange arm) didn't move when I changed the temperature so it was stuck to hot. I pushed it with my finger and it worked.
    If you get hot air from all vents could it be a fuse?
    Nathan
