EM TuningAH Fabrications
Results 1 to 14 of 14
Thread: VOLUME ADVICE
    Oct 2009
    73
    VOLUME ADVICE
    Can anyone advise me on how I adjust the volume on my radio/satnav system, when I turn the key it comes on to loud, I cant find the hand book on my satnav and have tried all sorts to sort it, any ideads chaps. Cheers (2007 S-Line Model RNS-e)
    Jul 2010
    Kent
    175
    Turn the nob with the power symbol on it mate.
    Four Sprung Ducks
    shawshankuk's Avatar
    Glu Kru
    Sep 2006
    Scotland
    60
    Quote Originally Posted by Sam W View Post
    I think he means the loudness setting lol.
    I was reading a bit in my manual a while back that you can have the system come on at a certain loudness everytime you switch the ignition on.
    You can adjust this but I cant find my manual just now. Maybe someone else can help.
    Brrrrrm Stcch...... The sound of that Turbo... Schwing!!! A3 1.8 Turbo 1999 Lowered 40mm, Rs418's, Sony Explod Cd, Vibe Component, RAM Cold Air Indutcion, Cat Back Remus Exhaust,Green Stuff Pads, A colour to die for.....
    mikeyw's Avatar
    Jan 2011
    135
    There is a setting on my Audi Concert. I can't remember what it's called though. Something like 'On-Volume'.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    My RNS-E comes on at the volume it was set at when the cars turned off. Try looking/posting in the SatNav/I.C.E. section of the forum.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Oct 2009
    73
    Thanks for all the sensible advice thus far, still cant find what I need but it would be nice to have the volume come back on at the same level it was turned off at. Still looking for inspiration as to be honest it is a little bit of a pain as it comes on loud but like the wise man said "try turning the power button" the depth of intellect on this forum is nothing less than astounding. Thanks so far chaps.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Do you have a Multifunction steering wheel?
    RNS-E retrofitted
    Oct 2009
    73
    Yes I do mate, why ?
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Just a suggestion and I don't know if it'll make any difference to your problem but I always leave the unit volume button at halfway and always control the volume by the steering wheel controls. Maybe even try turning the unit button to minimum, see if it helps.
    RNS-E retrofitted
    807
    You sure there's not a "on-volume" setting on the rns-e? there is on the Symphony 2+
    Feb 2011
    on mine (concert) you press the menu button then hold it, and then scroll to 'volume on' or 'on volume' and change it there, not sure if it would be the same but thought it was worth while atleast letting you know
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,537
    Quote Originally Posted by benr View Post
    There isn't - but for some people (me included) this works.
    Go into Engineering Mode and select the screen that shows the volume, set that to the turn-on volume you want and turn the RNS-E off and back on.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jul 2010
    Kent
    175
    Archie I was only trying to help, don't be *****y about it, otherwise next time I won't even bother.
    As with Dave mine is set to come on at the level the unit was turned off at, but is also linked to the key, so that should the spare key be used to start the car a different set of settings are used for the rns-e, the seats and the heating. I'll go through the menu later but I'm pretty certain that the units are set to do that by default and don't remember seeing a way to change them.
    Sam.....the wise man....
    Four Sprung Ducks
    Oct 2009
    73
    Thanks for the advice, will keep on trying, was not being *****y but in all fainess your answer(Sam W) lacked any help or direction i.e "turn it down" and I was not the only one who thought so however, sorry did not mean to offend. Thanks
