Volks AutosSky Insurance
Results 1 to 11 of 11
    Dec 2010
    223
    a4 tfsi timing chain
    as above has any one had to change one if so at what cost i thing mine is slightly noisey
    Paul N Ireland's Avatar
    Mar 2011
    95
    Oh yes, I done mine when I first bought it. I have no idea about labour costs as I done my own at the time of timing belts ect but I would expect to pay around the 200 range. The chain and tensioner from memory is around 100 - 150
    Mar 2009
    589
    2.0tfsi has a cam belt doesnt it not a chain? Some one more technical may correct me though but thats what I had changed by local indy!
    Your looking at arround 300 but I dont think you should change it unless due no point bare in mind the tfsi engine is noisy at idle even when healthy I think its some thing to do with the fsi technology I seem to remeber reading!
    If you do get cam belt changed make sure water pump is done at the same time!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    marrow the tfsi has a belt and chain
    parts around 150 and prety easy to change but tight
    around 300 in labour to change
    Mar 2009
    589
    See I told you someone more technical would correct me ! lol
    When should chain be changed then ?
    Mar 2011
    95
    Just when it starts rattling. If it does not rattle, you dont
    Dec 2010
    223
    the chain rattles only on over run
    bez101's Avatar
    Jul 2008
    8,480
    are you sure its the chain thats makeing the noise ?
    Dec 2010
    223
    sounds like the chain and tensioner thanks
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    But the tfsi uses a belt!
    Mar 2011
    95
    Quote Originally Posted by Chris79 View Post
    They use a belt for cam to crank timing but the two cams are linked at the rear of the cylinder head by a chain
