Chris NottMonster Motorsport
    Blackie's Avatar
    Feb 2004
    In a house
    634
    A4 Cab Window problems
    Hi All
    I have some problems with the drivers window on Julies Cab.
    Its getting worse at the moment and becoming a right arse.
    The window drops on opening the door but sometimes does,nt go back up. This drops again when you open the door and then leaves a bigger & bigger gap. If you close the door you can take it back up again most of the time but occasionally ALL 4 of the buttons AND the open close button for the door locks will stop working until i turn off the ignition & turn it on again.
    I cannot operate the windows when the door is open from the switches.
    Julie most of the time now has to climb over the seats & get out the left side of the car.
    I connect the VAG up & get a warning od Drivers control module intermittent
    Can anybody shed some light as to what part i will need to fix this
    kite's Avatar
    Oct 2007
    East Berks
    659
    check for broken wires in the loom between the door and "A" pillar
    A4 (b6) 2.5 TDi QS Saloon.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Ok mate thanks.
    Also noted that the illumination on the drivers door is now not working. Looks like it may be cable related. Arse
    Blackie's Avatar
    Feb 2004
    In a house
    634
    And the door isn't locking either now so I have to set the alarm and lock the door with the key.
    As the fuse does both doors i am now assuming perhaps a common positive wire is broken as the buttons for the alarm at the bottom of the door also don't work
    Anyone else had this problem ?
    Mar 2008
    83
    I know there were issues with the comfort control unit which is located under the drivers seat gets wet and fails causing similar symptoms although this was on the B6 not sure if it still occurs on the B7. I'd agree that broken wires in the loom between the door and the A pillar is a very good shout, however check very carefully as the breaks are not always visible from the outside of the insulation.
    08 Audi A4 2.0TFSI Cabriolet Special Edition, Electric seats, RNS-E Satnav, OEM BLuetooth, SmartTop
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Sorted the *******. The main brown wire in the loom was broken, now soldered and shrink-wrapped and all working again
