- Joined
- Feb 6, 2004
- Messages
- 702
- Reaction score
- 80
- Points
- 28
- Location
- In a house
- Website
- www.desmocorse.net
Hi All
I have some problems with the drivers window on Julies Cab.
Its getting worse at the moment and becoming a right ****.
The window drops on opening the door but sometimes does,nt go back up. This drops again when you open the door and then leaves a bigger & bigger gap. If you close the door you can take it back up again most of the time but occasionally ALL 4 of the buttons AND the open close button for the door locks will stop working until i turn off the ignition & turn it on again.
I cannot operate the windows when the door is open from the switches.
Julie most of the time now has to climb over the seats & get out the left side of the car.
I connect the VAG up & get a warning od Drivers control module intermittent
Can anybody shed some light as to what part i will need to fix this
