JMB RetrofitsChris Nott
Results 1 to 17 of 17
    Dec 2010
    222
    audi a4 dtm power increase
    what is the max bhp and torque i can get from this car before further mods thanks and who to use
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    I dont understand the question?
    Mafia black 2007 A4 S-line 2.0Tdi - RNSE - Bluetooth - MFSW - GSM phone prep - Privacy glass all round - Cupra R splitter - Black Grill, surround and fog surrounds - 12" sub and 1200 watt JBL Amp - AP Coilovers - 19" RS6 Alloys - 6mm f & 15mm r spacers - Carbon wrapped interior - Blue LED dials - Ambient Lighting - Cruise Control - HID's - LED side lights - mapped to 185bhp / 380nm - Twin exit exhaust - RS6 style DRLs
    Avantageous
    Apr 2010
    Hampshire
    337
    I believe he's asking how much power will you get from just a remap with no other mods.
    And I believe that the engine is the same as every other 2.0TFSI so the increase is not as much for a DTM as a standard 2.0TFSI. Should be looking at 250-260BHP though. As for who to go for, well some people stick to the big guns (Revo, Custom Code etc) and some just go for the little companies (more-bhp etc). You will pay a lot more for a Revo map than a more-bhp map. I personally haven't got a remap yet, but will be getting a more-bhp remap sometime in the near future. Have read good things about them, and for 200 its the cheapest around.
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Before you map it get a panel filter and a full system exhaust if you can afford it. this will make a world of difference when you map it and the car will be so different. costly but worth every penny.
    Jul 2010
    Kent
    175
    If you did the fuel pump you'd also see a fairly decent return once mapped, certainly 260+, but after that its injector and turbo changes I'm afraid....I say afraid, you'll likely see around 350+ with the right turbo and injector combination...
    Four Sprung Ducks
    Dec 2010
    222
    what turbo can i use and injectors what cost etc
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    IIRC S3 injectors and a K04 turbo will be a good start. ask Bez101 or Solaris. they both have this or similar set ups.
    Jul 2010
    Kent
    175
    S3 Injectors coupled with a k04 as suggested, or a GT28RS, a quick google for the APR stage 3 kit will show you the kind of things involved and rough costs.
    Four Sprung Ducks
    Jan 2011
    I got our lasses car mapped by DNA tuning and she is very pleased with the results. There are no real gains to be had from the cat back exhaust so just decat and stick woth the standard cat back piece.I would recommend uprating the clutch if you want to go any further than stage 1 though. Fuel pumps are really needed also past stage 2 and these are costly and could add to the problem of fuel getting into the oil due to the increased fuel pressure.
    Avantageous
    Apr 2010
    Hampshire
    337
    Anyone know where I can get any decat/test pipe here in the UK?
    solaris's Avatar
    Slough, Berkshire
    404
    Quote Originally Posted by ChrisFurlong View Post
    I'll be carrying out a Hybrid k04 conversion shortly and will be selling my current test pipe/de-cat pipe. I'm hoping to complete the work in the next couple of months if you can wait that long?
    solaris's Avatar
    Slough, Berkshire
    404
    And I believe that the engine is the same as every other 2.0TFSI so the increase is not as much for a DTM .
    Not entirely true,
    The DTM has BUL engine code and has a lower compression ratio (10:3 in comparison to 10:5) than some of the other 2.0 TFSi A4 engines.
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    Avantageous
    Apr 2010
    Hampshire
    337
    Quote Originally Posted by solaris View Post
    Yea I may be interested. But I'm also looking to do the K04 conversion and know you need to change the flange on the turbo side of the pipe. Are you getting a new pipe made? Or are you changing the flange on a K03 pipe?
    chrisa4quat's Avatar
    Sep 2004
    897
    Not entirely true,
    what does this mean?
    solaris's Avatar
    Slough, Berkshire
    404
    Yeah i've had a new pipe made with a custom K04 flange
    solaris's Avatar
    Slough, Berkshire
    404
    Quote Originally Posted by chrisa4quat View Post
    So generally speaking a lower compression ratio would give more power/BHP @ higher RPM but at the sacrifice of less torque at lower RPM. Now the interesting thing is how was the difference in compression achieved? Piston size? Gasket thickness? Evidence suggests that the DTM has different internals one would have to check out the part numbers to be conclusive.
    Dec 2010
    222
    thank u for comments going to check on up rating my dtm
