JMB RetrofitsChris Nott
Results 1 to 13 of 13
Like Tree3Likes
  • 3 Post By Kaysvay
Thread: HELP - A4 2.0 Tdi Engine Problems
    Feb 2007
    Manchester
    138
    Question HELP - A4 2.0 Tdi Engine Problems
    Hi All,
    I will try to be really short...
    I have a 54 Reg A4 2.0Tdi 140 (B7), 96K miles.
    Symptoms:
    1- No power at low RPM (nothing until 1900 rpm), nowhere near what a 140 should be like
    2- loads of black smoke (I mean LOADS) under hard acceleration; not so much when accelerating slowly
    3- idling at 950rpm, is it normal?
    4- when stationary, along with the usual diesel noise, there is a non regular tapping noise coming from around the alternator; any idea?
    5- Combined MPG is....34MPG....
    Recent VAG com check showed:
    1- EGR overboost
    2- 2x glowplug issue
    The garage doesn't know what to do (has been 6 month that they do not know...)
    I thought about a sticky vane turbo situation and looked at Innotec but I did not want to go ahead without second opinion.
    Any idea?
    Thx for your help guys.
    Black 05' Audi A4 B7 2.0 TDI 140 SE Saloon...
    Feb 2007
    Manchester
    138
    No idea anyone?...
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    If your car was going into limp mode, i would have suggested the Innotec Turbo cleaner like you suggested, however because you have a EGR problem and glow plug issues i wouldn't bother with that.
    Your glowplugs could be shot, and so smoking a lot under heavy acceleration. The glowplugs stay on, and do not turn off within the first few minutes of starting a diesel in cold weather so if yours arent working, the fuel won't be burning correctly in the cold and thus heavy smoke.
    So the question is, does yours smoke a lot constantly? even after the engine is fully warmed up?
    I'd pop into Awesome GTI and have the boys have a look. They are excellent and not as expensive as you may think.
    Cant help with the EGR fault. Perhaps you should give it a clean out?
    Things to do: Lower on coilovers, spacers, front end respray and a full correctional detail!
    Feb 2007
    Manchester
    138
    Hi Fahim,
    Thanks for your input.
    The black smoke is constant all through, even if the temp goes 90C and it always happen under hard acceleration.
    Either way, it is so sluggish that glowplugs only cannot explain it imo.
    The black smoke is quite bad so I suspect a clogged up EGR valve, and turbo maybe...
    IT does go to Limp occasionally after hard acceleration though.
    Thanks for your help.
    K.
    Feb 2007
    Manchester
    138
    Ok, Full service booked with Awesome GTI, explained the issues.... Keeping posting when I have more news...
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    Good to hear, let us know the outcome. I'd be interested in what the problem was! :-)
    Feb 2007
    Manchester
    138
    Hi there!
    Ok so go the car back from Awesome... but it is not fixed yet as it was on a saturday.
    Anyway, I got the following codes:
    01543 - Parking Aid Warning Chime (H15)
    006 - Short to Plus
    01547 - Sensor for Parking aid; rear Mid-Right
    004 - No signal communication - intermittent
    17055 - Cylinder Glow Plug Circuit (Q10): Electrical fault
    P0671-000
    17057 - Cylinder Glow Plug Circuit (Q12): Electrical fault
    P0673-000
    17058 - Cylinder Glow Plug Circuit (Q13): Electrical fault
    P0674-000
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000
    16485 - MAF Sensor (G70): Implausible Signal
    P0101 - 000
    Right now, the CEL light came back on yesterday.
    Black somke is still full on under hard acceleration and it is still sluggish. After the full service the MPG got better so this is the good thing at the mo.
    So it seems basically that I have to replace 4 glow plugs and check the parking sensor circuit, and finally tackle this Overboost and MAF condition.
    Any idea?
    I was looking at the engine bay and I could not locate the glow plugs: where are they? Also which glow plugs should I buy? is it something I can do on my own or is it another trip to the garage....?
    Cheers for your help!
    Feb 2007
    Manchester
    138
    anyone?
    Jul 2006
    Kingston upon Hull, United Kingdom
    178
    I have recently changed my glow plugs and it was a bit of a twat of a job as they are under the rocker cover deep down inside - it is do-able but be patient and give yourself an hour or so
    During a 4 wheel drift on the M25 i hear from my mate "Dont you ever do that again! Gimme the keys" after 12 hours of owning my old S4
    Aug 2006
    Johannesburg, South Africa
    Hi,
    I have a A4 B7 2.0 TDI 103kw BLB engine with 268k km on the clock. I had 3 out of your 5 Symptoms:
    I tried all these with no luck:
    Injector Cleaner, turbo VNT cleaning, decat, cleaned motor intake flap and drained all the diesel from the tank
    In my case, It turned out being a faulty EGR - it was stuck in the open position. blocked it off at the cooler and at the motor flap@intake manifold sections and its running perfectly for over a year with NO error codes.
    I just used 1mm piece of steel to block it off.
    Hope it helps
    Feb 2007
    Manchester
    138
    Kaysvay,
    I have the same symptoms but could I ask you how exactly you did it as I would like to do the same. Did it affect the MPG?
    Cheers.
    Aug 2006
    Quote Originally Posted by A4NA18 View Post
    Kaysvay,
    Cheers.
    MPG - my daily commute changed from highway to city driving so I cant really compare them. Current Avg is 7.0l/100km
    I added the steel plates in the red highlighted areas:
    The brown "thing" is a paper gasket that I added afterwards. its optional.
    If it is the EGR thats stuck open, then I suggest you clean the intake manifold (and replace gasket) because of all the exhaust soot.
    Good Luck!
    A4NA18, Rheady and S77NGY like this.
    May 2012
    Black smoke is an indication of overfueling
    Black smoke and low power is an indication that the turbo is shot.
    It's posible that the sensors in the system are malfunctioning and overfueling the engine.
    If you don't let a turbo engine idle for a couple of minutes before turning it off, you will prematurely destroy the bearings in the turbo.
    This is caused by no oil being pumped to a bearing that is still spinning at high rpm. So if this sounds like you, you probably have a bad turbo. If it grenades, you've got a blown engine.
Tags for this Thread
