JMB RetrofitsChris Nott
Results 1 to 8 of 8
Thread: Rear tyre wear
    shawshankuk's Avatar
    Glu Kru
    Sep 2006
    Scotland
    60
    Rear tyre wear
    Hi folks,
    I just got my A4 this month and loving it however, when i went to pick it up the brakes were guffed so i replaced all four corners myself this morning.
    When taking the back wheels off i noticed that the outer edge of my tyres are to the limit but the inside is like new. All four tires were put on the car about 7 months ago and the fronts are still like new and their wear is just like it should be.
    I remember reading a while back that some people had issues with rear camber, toe etc but cant seem to find the thread again.
    The 4 tires are uniroyal rainsport 2's. My conclusion is that the guy who had it before me my have been an overly eager driver or the tracking and camber is out.
    My car is a 2.0tdi S Line Avant 2006 fwd. I understand that being a diesel, the torque can wear tires down prematurely but i thought since its front wheel drive, this shouldn't happen on the rear or does it?
    I need to get 2 new tires for the rear but before i do i wanted to ask all the pro's on here first.
    Also, can anyone recommended tires? Uniroyals are a bit pricey for me @ Ł165 each corner.
    Help appreciated or any links to old threads on this.
    Brrrrrm Stcch...... The sound of that Turbo... Schwing!!! A3 1.8 Turbo 1999 Lowered 40mm, Rs418's, Sony Explod Cd, Vibe Component, RAM Cold Air Indutcion, Cat Back Remus Exhaust,Green Stuff Pads, A colour to die for.....
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Maybe he swapped them front to back.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Or left to right, rears seems to wear on the inside, its the default setup of the car.
    Glu Kru
    Sep 2006
    Scotland
    60
    yeah, i sure i had read a thread before on rear tyre issues before i bought the car but i cant find anything now. Im going to take it to my local and see if there is anything seriously wrong.
    thanks for the replies
    solaris's Avatar
    Slough, Berkshire
    404
    Fisrt point of call would be to check the alignment including camber, no point getting new wheels only for this to occur again. With regards to tyres there are a few members on here that swear by VREDESTEIN ULTRAC SESSANTA think they are around Ł118 on camskils website.
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    Glu Kru
    Sep 2006
    Scotland
    60
    Thanks for the advice re tyres. For me its a problem getting them fitted. Most places refuse point blank if i want to supply tyres or they charge rediculas amounts for fitting.
    Im in Edinburgh and i have booked the car into CLCM in sighthill for a full tracking, camber and toe check. will get this done before i buy some new rubber. Its only costing Ł57 all in including adjustmnents.
    Was also looking at avon ZZ3 tyres as i can get these fitted for Ł111 per corner. Anyone have first hand experience with these?
    807
    I used to find that going to a kwik fit or similar and offering cash in hand to fit tyres to rims got it done fairly cheap probably Ł5-Ł10 a corner depending on who you get.
    I however really don't like Kwik fit actually I haven't found a tyre place I like at all. Seems to be full of knobs.
    Next time I replace a tyre which is "planned" (i.e not needed straight away) ill probably go onto black circles and get it booked into somewhere through them.
    Glu Kru
    Sep 2006
    Scotland
    60
    Thanks for the replys on this.
    Finally got it sorted.
    Booked my car into CLCM at sighthill Edinburgh.
    Turns out that fronts were swapped to back however, all four corners were needing adjusted but that's me driving straight now.
    Just in case your interested it cost me Ł49.50 for a full alignment check and adjustment.
    Just got my timing belt to get done at star perfomance in April and Im sorted but I wish I could scrape enough together for a remap.
