Volks AutosBadger5
Results 1 to 17 of 17
Thread: wobbly A4 cab!
    Feb 2011
    Nottinghamshire
    15
    wobbly A4 cab!
    Hi I wonder if anyone can please help, I'm new to the world of Audi and have bought a 05 plate A4 S-line Cabriolet in dolphin grey which has started vibrating through the steering wheel and pedals when on slightly rough road surfaces and becomes un-bearable on bad surfaces. I thought i'd solved it when I realised that I'd jet washed the weights off the alloys, so off i went to the garage but still getting the same vibration the only other notable thing is that i have pumped up the tyres around the same time as the jet washing incident as when I bought it they were at around 33 psi so I took them to 38 psi, could it be a tyre fault?
    Any help with this would be greatly appreciated as it is wrecking my Audi experience
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Is 38 psi correct for your model?
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Feb 2011
    Nottinghamshire
    15
    It says 41 i tried that first but was getting the same problem so tried dropping it down a little to see if it made it more comfortable but unfortunately not
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Sounds as though you have play somewhere, try jacking it up and feeling for any movement.
    RNS-E retrofitted
    North Wales
    39
    My 08 S-Line cab on 235/40/18 says 33psi all round, well thats what the door sticker says. Do they differ by model year?
    Feb 2011
    Nottinghamshire
    15
    I'm not sure if they differ, mine has the same size tyres the door sticker says 38 or 41, i really need to double check it though surely thay can't be that different.
    Don't think there's a major problem movement wise as it went in for service(non audi) and I mentioned it so they checked the suspension, joints and the like and said it was all fine which makes me think tyres
    Feb 2011
    Nottinghamshire
    15
    Just checked it defo says for 235/40/18 38 psi next to the picture with 2 people and 41psi for the one with 4 people, sounds odd though if your 08 reg says different!?
    North Wales
    39
    Just been out to check mine (2.0TDi 140BHP) and it say.
    33psi for 2 people, upto 100mph
    36psi for 2 people, over 100mph
    42psi for 4 people
    Feb 2011
    Nottinghamshire
    15
    Ok thanks, I think I'll be taking a trip the the garage to drop them to 33psi to see if it makes it better, I'll keep you posted
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    It depends on which engine size aswell. My pressures are 42psi all round, going up to 46 when it's fully loaded.
    RNS-E retrofitted
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,703
    It also depends on the accuracy of the pressure gauge on the airline you're using.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Feb 2011
    Nottinghamshire
    15
    Its a 2.4 petrol, I'm hoping its as simple as dropping them down 5psi otherwise I'm baffled with the garage saying that the suspension/bearings/shockers are all ok
    Feb 2011
    Nottinghamshire
    15
    Ok depressed the tyres to 33psi and its made it slightly, very slightly better but i can still feel vibration through the pedals on anything but very smooth road surfaces anyone got any more suggestions? otherwise this is going to be the shortest time I've owned a car at 6 weeks :O(
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    The thing is, it's very hard to replicate the loads put on the suspension parts by hand. Even the slightest wear felt by hand is multiplied when it's loaded up. Have you spun the wheels and listened/felt the bearings for any noise or grinding?
    I take it you got your tracking and 4 wheel alignment checked?
    If you suspect it's a wheel or tyre, why not try sticking your spare on, one side at a time and see if it makes a difference.
    RNS-E retrofitted
    Feb 2011
    Nottinghamshire
    15
    I got the garage to check all the joints, bearings, suspension when it was serviced 2 weeks ago they said everything was ok and i needed to look into the tyres/balancing so that's what I'm trying. Its due some new tyres on the back so i think I'll take it in and have the new ones on the front and move the current fronts to the back see if that solves it
    Feb 2011
    Nottinghamshire
    15
    Ok I'm back the problem seemed to subside over the last few weeks but now its back :O( The only significant thing I could think of is I have filled the car up with fuel and its been horrible since, could it be weight related? I have no idea what components of the car that would affect that would cause this annoying vibration, please help :O(
    Mar 2010
    Manchester
    7
    I've got exactly the same problem with my 1.8T Sport. Indy checked and said found nothing. Had new front tyres, all re-balanced, 4 wheel laser alignment. 2nd indy suggested front lower rear arms were worn, so replaced those. Problem still there. From what I've read, it could be a anything from wear in shocks (not leaking and 'feel' okay so wouldn't be easily spotted on inspecion) to an imbalance in the propshaft or even a bent wheel, although I would hope this would be spotted when balanced. Adds up to an exensive process of elimination, from what I can make out.
    I feel like you - it's wrecked my enjoyment of the car and is really denting my love of Audis. Spent all my hard earned buying it, so can't afford to chuck hundreds at it.
