Parking sensors retrofit
lionyo
Midlands, Birmingham
Hi,
I have a donner car that I want to remove the parking sensors off and put them on to my car!
How hard is it and what would it require doing/buying?
Many thanks!
It's not a job I'd fancy taking on. Means drilling your bumper, might have to cut and splice all sorts of wires (I'm not sure if there's a connector) and again will need coding.
I have no idea but AFAIK there are markings on the inside of the bumper for drilling. But as TOG said wiring could be a mare.
If I was going to retrofit id probably go for a universal kit as there's nothing special about OE parking sensors.
Have you seen this note on retrofitting? There are other resources about it on car repair guides and I have read from it that fitting them is a really easy DIY job. Usually it takes an hour unless you need to take the bumper off.
828
17
2K
2K
