Chris NottMonster Motorsport
Results 1 to 10 of 10
    Jan 2011
    17
    DIS Info help needed
    I am hopefully going to fit the wiper stalks with the buttons at the weekend.
    Just wanted to check first as I don't have vag com to code it so if I fit it would it still work the wipers until I can find someone to code it for me or does it need to be coded to get all the functions to work??
    Audi A4 Avant 2.0 TDi Sline
    yorkster001's Avatar
    Aug 2010
    York
    84
    You'll have all the same functionality less the DIS button on the end.
    A4 (07) 2.0T FSI S Line - Dolphin Grey
    Mods: Remap, DIS, Washer Bottle sensor, AUX Input, Ambient Light, Puddle/Warning Lights, Aftermarket SATNAV/DVD, VAG-COM Tweaks.
    Future Mods:
    B5 Caps, H&R Springs, 19's
    Jan 2011
    17
    Cool sounds good knowing are weather i wanted to check first lol!
    Jan 2011
    17
    Ok, got the steering wheel surround off just wondered how the wiper stalk is removed as I don't want to break it!
    I can see some clips is this what holds it in place or is it screwed in somewhere?
    Do you have to take the steering wheel off?
    Hopefully im not sounding to stupid!!
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    You need to remove the wheel and the slip ring behind. You then will see the screws holding the stalks in place.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Aug 2010
    York
    84
    The following link is a guide for retro-fitting Cruise but it also shows you how to remove the wiper stalk.
    Guide - Retrofit Cruise
    Kudos to 'S4_marv' over on Tyresmoke for putting the guide together.
    Future Mods:
    Aug 2010
    York
    84
    The following thread over on Tyresmoke should also answer any questions you might have. It's worth a read before cracking on with the install.
    Retrofit DIS/Cruise
    Future Mods:
    Jan 2011
    17
    Sorry for late reply been working in scotland.
    Thanks for the links I didnt really want to take the steering wheel off as its a bit obvious to my mrs with what im up to!
    Jan 2011
    17
    Anyone know if there is a guide to convert the single dinn head unit to a double dinn headunit anywhere?
    Aug 2010
    York
    84
    I know the feeling, I did the DIS in a public card park on my lunch break to prevent the ear bending!!
    Future Mods:
