Sky InsuranceJMB Retrofits
Results 1 to 10 of 10
    Feb 2011
    A4 Avant climate control overheating?
    Hi
    I have an Audi A4 Avant 2.0 TDI S-Line. It's a 55 with 60K on the clock. I only bought it the other day. I am after some advice re a problem with the climate control (well, I think this is where the problem is....)
    Regardless of what temperature I have the climate set to, and regardless of whether it is on 'auto' or whether I have made vent/speed settings myself, the vents at the footwell blow out consistently (very) hot air. The central front-facing vents seem to blow out different temperatures too - the left one being warmer than the right.
    Also, on a reasonably long run, the dash just to the left of the sterring column gets very hot - almost too hot to touch for very long. When I turn the climate control off, the dash cools down.
    Clearly this is not right. Has anyone any thoughts on what could be the problem? Is it the climate, or is something overheating in there and as a result the air to the lower vents is being 'superheated', regardless of the temperature that it is set at?
    I'm also experiencing what I think is low mpg. About 42mpg on a very long motorway journey (300 miles) doing around 80mph. Could this be connected?
    Any help or advice would be appreicated.
    Cheers,
    Z
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    you need a scan to see what flaps are stuck
    or remove glove box and watch when you change settings very common for the flaps to get stuck or fail
    Feb 2011
    Cheers. Hopefully this is the solution, but not sure it explains why the dash is overheating?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I've now got the same problem, not sure if it is coincidence but I removed and repositioned my front bumper yesterday. I get very hot air from the left side dash vents but not the right hand side which operate normally. Is there a sensor near the front grill?
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    If you do remove your glove box, DO NOT turn on the ignition untill its all back together, i made this mistake removing my RNSE and its throws up the passenger airbag warning light.
    Annoying!
    Mafia black 2007 A4 S-line 2.0Tdi - RNSE - Bluetooth - MFSW - GSM phone prep - Privacy glass all round - Cupra R splitter - Black Grill, surround and fog surrounds - 12" sub and 1200 watt JBL Amp - AP Coilovers - 19" RS6 Alloys - 6mm f & 15mm r spacers - Carbon wrapped interior - Blue LED dials - Ambient Lighting - Cruise Control - HID's - LED side lights - mapped to 185bhp / 380nm - Twin exit exhaust - RS6 style DRLs
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Is the glovebox easy enough to remove?
    Nathan
    bez101's Avatar
    Jul 2008
    8,530
    very easy 5 bolts
    3 at top 2 at bottom
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I've taken the glovebox off. There appear to be three motors, the top two work fine. The bottom one doesn't appear to do anything but I don't know if it is meant to.
    Nathan
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Borrowed VCDS cable off B5Nut, temperature motor had a fault. Pushed it with my finger and it works again. I'll keep the glovebox offf so I can keep an eye on it.
    Nathan
    Oct 2009
    25
    Hmm, noticed his morning that whatever temp I have set, hot air comes out of the vents. I know the flaps move ok (new blower motor fitted) so where is the temp motor?
