Badger5AH Fabrications
    Feb 2011
    55
    'Engine oil pressure' warning light on 2004 Audi S4
    Hi, I recently bought a 2004 Audi S4 in immaculate condition and full Audi service history from a reputable dealer. 1 day into ownership, and after having driven 30 miles a red warning light 'engine oil pressure' came up - I checked the engine oil level and it was fine - car is in garage now and they suspect it might be a faulty sensor - but should I be worried about the health of the engine? What is the likely cause? Sensor fault? Any expereicnes with this sort of message?
    Simon
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    yes be worried and dont drive or start it till its been checked
    if its pick up pipe blocked you run the risk of ****ing your engine
    make sure they do a good check
    worst of its gonna be sump off new pick up pipe and ur sorted
    btw the oil preasure light aint nothing to do with low oil theres a diff light for that
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Yellow oil can symbol on DIS = low oil level, top up as soon as convenient
    Red oil can symbol on DIS = low oil pressure, turn off engine immediately and do not start it again until problem is found and fixed
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Feb 2011
    55
    Hi Bez - what do you mean by 'new pick up pipe'? ...and how much is that likely to cost? Thx
    bez101's Avatar
    Jul 2008
    8,480
    pick up pipe connects to the oil pump
    pulls oil from the sump
    and depends on the garages labour charges the pick up aint to much but its a sump off job
    did you try the sensor 1st ?
    Feb 2011
    55
    yep tried sensor and that is all ok...so looks like a 'sump off job'... any tips in terms of garages in surrey (ideally near guildford)?
