JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    Leak under car - normal?
    I've noticed quite a bit of oil like liquid under the car:
    I've run my finger through it and its not oil coloured, it's clear, it just has a sheen to it like oil. My first thought was it's the aircon condensing, which you usually get a bit of, but not to this extent...
    It's dripping from pretty much the back of the undertray
    Any thoughts?
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    but only when the engine's on, had a look through the engine bay but can't see anything obvious
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    well it could be from anywhere as it will collect on undertray and drop at the center
    is your coolant lever droping ?
    bez101's Avatar
    Jul 2008
    8,525
    can i see a pic of under your bonnet
    i wana se how you got the rs4 covers to fit
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    this is the old car with covers fitted, same as the new one:
    will check the coolant level in the morning
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    it is actually only one cover...
    bez101's Avatar
    Jul 2008
    8,525
    cheers for the pic
    i thought you ment you had the carbon covers fitted
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    nope, haven't got that kind of money lying around lol
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    coolant level's fine, hasn't been leaking further sat on the drive, think it must eb the aircon..
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I had a similar problem that turned out to be a cracked pipe on the power steering.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,246
    Just had an audi technician out, they've noticed the transfer box is weeping, thinks it's a leak from there.
    I also get a kind of juddering when accelerating hard, but not sure if that's normal for quattro as have nothing to compare it to (it's the first quattro I've had)...so they're going to check that out also for me.
    It's under Audi warranty and recovery, so they're taking it away for me and giving me a replacement car until it's fixed, glad I had that as could be expensive (maybe), although have only had the car for 4 weeks...
