Hi all, I've just bought some genuine audi a5 alloy wheels from ebay and the seller assured me they will fit my a4 B7 2006 cab, I've not tried yet but any thoughts?
Hi! I recently had a similar query.....The bolt pattern is the same so no problems there. The offset value should be stamped at the back of the new alloys ET....
Basically my B7 alloys were ET 43 and the new alloys were ET52......so needed to get 9mm from somwhere - hence getting spacers.....
Also you may need spigot rings (Plastic /nylon rings to fill the gap of the bore...) I thought i wwould need these as alloys were from a newer car - turns out I didnt....
