Volks AutosAH Fabrications
Results 1 to 34 of 34
    Mar 2009
    100
    New TT alloys on a b7 a4?
    Hi, I have the chance buy some original TT alloys from a 2008 model. They are et52 with a 245 /40/18 tyre. I think I would need spigot rings but do u know if they would be too wide?
    Mar 2009
    100
    Btw help appreciated!
    Mar 2009
    100
    Hi! Picked up some TTS wheels last night. they are 9J ET52 with a 245 / 40 /18 tyre.... look nice and beefy!
    Anyway - just wondering if they would require spacers or any of you folks running wider tyres?
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    easyest way is do a trial fit n check for ne rubbing on inner n outer of arches sit in boot also n give it a good bounce to make sure they wont catch nething when suspension travels do same with front and turn steering full lock both left n right n jus drive it slowly under full lock aswell
    also get some pics so we can c how they look
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    Apr 2009
    Coventry
    2,219
    Probably need spacers.Try this calculator to see the differance in sizes
    Wheel Offset Calculator
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Mar 2009
    100
    Hi thanks for the help so far....
    I believe the standard S-line 5 arm alloys from a A4 are ET43? not quite sure....will have to check and maybe just do a trial myself. Wheels will go on over the weekend and will try to get some pics up...
    Apr 2009
    Coventry
    2,219
    Yup, standard sline 5 spoke 18x8 have an et of 43
    Pass me my sock
    Mar 2009
    100
    Hi,
    Still havent had a chance to get the wheels on. this will probably be over the weekend now! Anyway -as i spend most of my time sitting at a desk (Sad I know!) was doing some calculations using the tools --
    Where it says EXTEND 4mm - Do you think I would need some spacers? Like 5mm ones?
    Current Wheel Specs Width inchesOffset mm New Wheel Specs Width inchesOffset mm
    Inner Clearance: 22mm LESS
    (the inside of the wheel to the strut housing)
    Outer Position:EXTEND an extra 4mm (position of the outside edge of the wheel)
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    I had 9j wheels at ET35 and they poked out of arches a few mm but prob wont be any good on the front so find something in the middle, on the rear use a 10mm spacer to take you to ET 42 which should be fine and 5mm to give you ET48, you should be ok on that providing you get caliper clearence.
    Mafia black 2007 A4 S-line 2.0Tdi - RNSE - Bluetooth - MFSW - GSM phone prep - Privacy glass all round - Cupra R splitter - Black Grill, surround and fog surrounds - 12" sub and 1200 watt JBL Amp - AP Coilovers - 19" RS6 Alloys - 6mm f & 15mm r spacers - Carbon wrapped interior - Blue LED dials - Ambient Lighting - Cruise Control - HID's - LED side lights - mapped to 185bhp / 380nm - Twin exit exhaust - RS6 style DRLs
    Mar 2009
    100
    Hi,
    Had a chance to see if the wheels fit.......firstly i thought there would be a gap on the hub bore - thinking that mine were 57.1 and new alloys were 66.6...............but no gap which was weird!
    Anyway - alloys look smart..........will need to get spacers though there is sum rubbing on the damper on the rears and also on the suspension arm on the fronts!
    Probably will get 10mm at the front and 10 or 15mm at the rears.........
    pics during the week!
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    The 66.6 cb is Mercedes. Are the wheel's stamped up as Audi.
    AUDI A4 190T S-LINE.
    Macdoon's Avatar
    Essex
    1,569
    Hi All
    My mate is getting rid of his 8x18 speedline alloys, the offset is et48, mine are 8x18 et43, haven't yet tried them on but will when I get the chance, in the mean time just looking or some advice. Do you think they will it?
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    They will fit as long as they are 5x112. The offset of 48 will mean the wheel's will sit in more so spacer's will be needed if you want the wheel's closer to the arch.
    Macdoon's Avatar
    Essex
    1,569
    Thanks CMD, so i need 5mm spacers all round to bring back to where it was, any recommendations where best to buy them.
    Mac
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Quote Originally Posted by Macdoon View Post
    Mac
    Mac i would go with 10mm spacer's which will give you et38 This offset will not cause you any problem's. Ebay is the place.
    AUDI A4 BIMECC HUBCENTRIC WHEEL SPACER KIT 10MM on eBay (end time 04-Feb-11 16:40:45 GMT)
    Mar 2009
    100
    Hi,
    Yep wheels are definatly stamped Audi with all the markings.....
    I think also the bore of the wheel is almost coned so that it would apply to a variable bore size.......bit of thinking done at the Audi design house!
    Anyway - anyone bought off eBay?
    Mar 2009
    100
    Mac
    Just to second that - im pretty sure the speedlines will fit at there is only around 5mm difference? Are the tyres sizes the same? i.e. 235/40/18? then IMO should be ok.
    My new ones are 245/40/18 also 9j ---- also et53 so wider and go into the arch more.......
    Macdoon's Avatar
    Essex
    1,569
    Yes the tyre sizes are the same 235/40/18, i will be trial fitting the wheels this evening, a mate has given me 2 5mm spacers to try.
    Mac
    Macdoon's Avatar
    Essex
    1,569
    Quote Originally Posted by CMD View Post
    will the 10mm spacers push the wheels out to far ? not being a techy just thought it might, again thanks for your input.
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    I have also been looking into spacers recently and general concensus is that ET35 seems to be the golden offset for the wheels to nicely fill the arches. Some may suggest that this is ever so slightly aggressive for the front and you could go slightly further out on the rear.
    My wheels are ET45 and I am planning to run 12mm on the rear and 8mm on the front giving me ET33 and ET37 respectively... I am yet to order though as the next question is who is the best for price and quality!
    Hope this is of some help to you?
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Spacing wheel's to ET35 is now common practice. With the 10mm as stated you will have et38 which will look nice. I have 15mm spacer's on wheels that are et45 and i have no problem's and the tyres are 235's.
    Macdoon's Avatar
    Essex
    1,569
    Thanks, so thats sealed it for me, 10mm all round, will get them, on order, thanks for the link
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Nice it should look the nut's. Mac Stick up some pic's when you have fitted them.
    Macdoon's Avatar
    Essex
    1,569
    Absolutely gutted, offered the wheels up to get an idea what they would look like, before buying the wheel spacers, glad I did, the hub is bigger grrr.
    A mate said I could have the wheels machined out, but I don't wanna go down that road.
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Why its not expensive and its perfectly safe, if you space them on say 6mm non hubcentric spacers wint they fit? think the hub might still poke out just enough but its worth a try.
    Mar 2009
    100
    Let us know how you got on Macdoon!
    I ordered 15mm all round last night!! wish me luck!! This will take the ET52 (new alloys) to ET 37.....hopefully they will fit. When i trialed them they sat quite alot inwards and also rubbed on the suspension arm.....
  28. #27
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    They will be fine mate, I have 15mm coming tomorrow also for my rear, I have 6 mm front so ill be running f ET39 r ET30 8.5j all round.
  29. #28
    Mar 2009
    100
    Hi All -
    Got the new wheels fitted. Really happy with the result. Look a lot more chunkier in the flesh! If anything I think I may have gone for 12mm in the front but then theres always the clearance issue!! The handling is flatter and Less prone to wheels spin!!
    Before
    After (Apologies for the crap res!)
  30. #29
    Nov 2006
    Queensbury
    9
    Hi Fast3000, did you have to use longer bolts?
  31. #30
    Mar 2009
    100
    786 Yali - Yes longer bolts and also longer locking wheel nut bolt! ; )
  32. #31
    Jan 2011
    111
    Hi all, sorry to jump in on this thread, but my newly aquired A4 Quattro has got some non genuine wheels with an offset of 33, they dont look bad other than the car does seem to get dirtier but my question is will this much offset upset anything? I will be changing the wheels once I can find some to replace them but I hope I dont need to just yet....
    Cheers, Phil
  33. #32
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    No mate you will be fine with them, you got pics?
    Fast where are you from mate?
  34. #33
    Mar 2009
    100
    Hi Phil,
    I probably can't answer your question.....but do the wheel stick out a lot? not sure how much this would cause you an issue?
    Triple OG - Im from London.....
  35. #34
    Jan 2011
    111
    Hi guys, no the wheels dont stick out much, when the weather is a bit better I will post some pictures, thanks for the info though. I will be looking for some RS4 wheels at some point so as to replace these wheels, they are black with polished rims, not my style in afraid.
    Phil
