Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Jan 2011
    walsall
    15
    windows steaming???
    hi.. just wanted to know if anyone knows why the windows on my 2.0tdi audi a4 b7 57reg keep on steaming up.. sometimes it gets really bad and i cant see f all out the window..
    what temp shall i have them set at and shall i leave the econ on???
    or is my matrix on its way out??? so confuseddddddd
    can somebody help me out please
    bearder2006's Avatar
    Jun 2009
    205
    its probs your carbon filter/polly filter
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    I find that swapping between running the aircon and switching to economy makes my car steamy, leaving it with the aircon on will dry it out. The temp is less important than air flow.
    If you press auto and 22c and it's still steamy you have a fault, could be damp carpet from shoes or a leaking door seal or as above system fault.
    Cheers Chris
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    The best thing is to open all the windows slightly (maybe 1 cm) then run the air con on max temp and flow for as long as you can. Select it on foot heating, as moisture is most likely to be on your carpets and the heat will rise anyway. If it still happens after that, then obviously look at filters etc. Its a cheap and easy way to start fault finding before spending money on parts.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Jul 2010
    Kent
    175
    Stick an open box of digestives on the back seat over night.
    Four Sprung Ducks
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    I also have the same problem with our 56 plate Avant - really bad condensation. Where are these filters that may need to be replaced?
    Other thoughts are - a possible leaking rear window washer, boot seals, door seals etc - basically I need to have a good look around it!
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Jan 2011
    walsall
    15
    cheers bud il try that ;-)
