Volks AutosJMB Retrofits
Results 1 to 12 of 12
    Jan 2011
    111
    New Car not right..
    Hi guys, well after a week of ownership I decided that I just wasnt happy with the performance of the car so I took it to a local Indy guy and had a diagnostic done. I wasnt surprised to be told there was a "low boost" fault. I am quite happy in a way as at least I know when its sorted it should be a great car! BUT, there was also a "low fuel pressure" fault too. Is this a known fault?? I am slightly concerned having read on the US forum about a cam follower issue, I have a definate "ticking" noise when the car is hot but had thought it was just an injector tick, now I am not sure.
    Has anybody got any input on this? the DV is a simple job but I am just not sure the guy I bought the car from will dig into this other problem.
    Thanks, Phil
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    what car is it how many miles etc etc
    the low pressure could be the sensor on the HPFP easy fix have you got the codes ?
    Jan 2011
    111
    Sorry, should have said... its an 06 2.0t Quattro, 51k with apparent full service history. I have to assume the guy I bought will do the right thing, but I dont trust car dealers! I worked for a couple.
    bez101's Avatar
    Jul 2008
    8,530
    thought so
    the ticking is normal they sound like diesels
    the low pressure can come cos of the DV and the DV is very common get a forge that will last even with a stage 3 remap
    the low pressure can also be the side sensor on the HPFP iv just changed mine very common for them to go
    are you getting bad fuel cuts ?
    Jan 2011
    111
    Thanks for that, I feel a bit less stressed over it now. The car is going back to the garage I boiught it from for them to fix today, they want it all week to be sure they get it right so fingers crossed it should be right after.
    19
    How did it go?
    Jan 2011
    111
    So far it's been a nightmare, the dealer has been great, he had a local guy try to fix it, but they didnt know what they were doing, they changed the turbo wastegate! then he let me put it into my local indy, they replaced four parts including the DV, the dealer paid and all was good, for a week!!! Now its back in the indy, got towed in tihs week after a coil pack burnt out and fried all the wiring....... Not have a good time of Audi ownership so far.
    bez101's Avatar
    Jul 2008
    8,530
    what have they changed did you get the codes ?
    the low preasure could be the G 410 on the hpfp
    at worst could be the hpfp follower and cam
    id the indy up on audis ?
    the coilpack melting aint to bad it happens on the 2.0T the loom is prety easy to change
    Jan 2011
    111
    I just picked it up from the garage, 370 quid all in, that was two coil packs (1 spare) plus the labour for diagnosis, they eventually found the melted coil pack had managed to fry a couple of connectors even though the fuse had gone to protect the circuit. God I'm glad I didnt take to Audi.....
    Just one thing, now I have a spare coil pack what tools do I need to change it? it doesnt appear to have any screws holding it in so is it just a push fit??
    Cheers, Phil
    bez101's Avatar
    Jul 2008
    8,530
    370 and not at audi dealers
    god did it hurt 2 packs a conector and a scan
    hope he lubed you up 1st
    bez101's Avatar
    Jul 2008
    8,530
    and yes its a push fit
    Jan 2011
    111
    Hmm, that was 3 hours labour, they say they couldnt find out why it was all dead even after changing the fuse! oh and there was a recovery in there too! still bloody expensive though.
