Volks AutosMonster Motorsport
    Jan 2011
    walsall
    15
    THREAD ON MY OFFSIDE WHEELS....
    hi ppl.. would any1 know why the thread on my offside wheels are wearing more than the nearside???
    nothing seems to be wrong with the tyre pressure and traking juswt recently got goodyear tyres put on!
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    By how much difference is the wear rate.
    Tracking in my opinion is not worth much , to make sure everything is spot on you need 4 wheel laser.
    I used these for many years .
    center gravity : suspension & geometry tuning
    Chris really does know his stuff .
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    mitch2575's Avatar
    Oct 2010
    112
    I had the same problem on my B6 it turned out the bearing was on the way out!
    1.8T Quattro Sport - Stock at present!
    Wish List - Remap, Sounds, AIR RIDE! & Shoes!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,309
    When I read this, I thought you were referring to the threads on the wheel bolts, not the treads on the tyres.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Jan 2011
    walsall
    15
    lol sorry my bad mate i meant treads.. its about 3mm difference compared to the nearside..
    i think il get the bearings checked first and then il do the 4 wheel laser.
