Badger5Chris Nott
Results 1 to 8 of 8
    Jan 2011
    20
    Audi Concert to Audi Nav+
    Guys,
    Can you tell me if it is simple to swap out an Audi concert stereo for the Nav+?
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Do you mean to an RNS-E.
    All depends is your head unit a single or double din unit .
    If its a single din then more work is involved as you have to covert it to a double din.
    If you already have a double din the the upgrade is alot easier.
    HTH
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Post
    This will give you a better idea .
    RNS-DVD
    F
    Jan 2011
    20
    Sorry for my ignorance but what is single or double DIN? and yes I did mean RNS-E
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    It relates to the size of the head unit
    Double din
    single din
    As you can see the climate control is lower down on the double din , you can do this either buy a new climate unit thats meant for a double din or you can trim yours down .
    Again read here , someone is asking a similar question .
    RNS-e Signle Din Retro Fit
    F
    Jan 2011
    20
    Thanks for the info. Mine is a double din which i guess will make the job easier. The last link you gave me looks like a place I should speak to however none of the stereos on show looked like mine.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    If you have a double din unit already it's a straight swap .
    Keep an eye on ebay alot on here get them off there.
    F
    Jan 2011
    20
    Thanks I will keep my ear to the ground
