Volks AutosChris Nott
    Jan 2011
    walsall
    15
    audi a4 2.0 saloon 57reg / Vibration at idle?
    hi.. iv gt an audi a4 2.0 saloon 57reg and for some reason when the car is idle i notice a slight vibration in the car.. does any1 have a clue what this problem could be or is it an common problem for audi's????
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    It could be the dual mass flywheel, it's a common problem but quite expensive unfortunately.
    I'd run some injector cleaner through it first though, as a cheap fault finding exercise, just to rule out a fuelling problem.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Jan 2011
    walsall
    15
    cheers m8
    quick question..if i put the clutch in and it doesnt stop the vibration does that still mean it could be the flywheel?
    if im right when the clutch is dipped it should stop the vibration if its the flywheel....
