hi.. iv gt an audi a4 2.0 saloon 57reg and for some reason when the car is idle i notice a slight vibration in the car.. does any1 have a clue what this problem could be or is it an common problem for audi's????
It could be the dual mass flywheel, it's a common problem but quite expensive unfortunately.
I'd run some injector cleaner through it first though, as a cheap fault finding exercise, just to rule out a fuelling problem.
cheers m8
quick question..if i put the clutch in and it doesnt stop the vibration does that still mean it could be the flywheel?
if im right when the clutch is dipped it should stop the vibration if its the flywheel....
