Monster MotorsportEM Tuning
Results 1 to 12 of 12
    807
    Is there a "run in" period after timing belt replacement
    Always wondered if there was some run in time/distance after a timing belt replacement?
    Mine will need doing towards the end of the year
    Mar 2009
    589
    Hope not just had mine done and have been giving it the usual amount of right foot since I got it back !?! lol
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    No run in period.
    Just had mine done .
    Get these done at the same time.
    1)water pump
    2) tensioner & bolts ( they should do this as a part of it but make sure they do as some try to cut corners and use the old .
    3) aux belt .
    Where are you based , i just had all this done at an indi at a good price.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    807
    I'm in South East and West London.
    Ill be asking for genuine parts (due to warranty) and IIRC tensioners come in the timing belt kit. Also will be asking for waterpump.
    Is Aux belt really needed as it can be changed pretty quickly and easily anyway if it goes.
    Not sure where I will go yet but I know Audi website shows 400 for cambelt. Probably just go to my usual garage though, I will get plenty of quotes.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    If you go to an authorised indi they have to use OEM parts.
    The reason i said about the tensioner bolts is yes its in the kit ,but on another forum members car they tried to cut a corner and usr the old bolts which resulted in one of them shearing wrecking the engine .
    I had the aux belt done just a matter of course as they were working on it , i don't have to worry about it again.
    I paid 412 for all the above so that should give you some ball park figure to work with.
    F
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    My dealer charged 350 for cambelt and water pump. Didn't think it was bad.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Good price .
    Usually 399 just for the belt.
    F
    807
    Cheers,
    Whats an authorised indi?
    Who re they authorised by? does it really matter?
    Yep 350 seems cheap for a audi dealership. Website says 399 for a timing belt change.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Quote Originally Posted by benr View Post
    Cheers,
    This is where i had mine done , it will explain it better than i can.
    VW Volkswagen Audi SEAT Skoda - Warranty Information
    HTH
    F
    807
    Cheers for the link, they look good, too far away though.
    I still don't see anything about it being "authorised". Just - "providing parts matching original specification are used and the manufacturer's service schedule is followed"
    My warranty is extended 3rd party with AA now and they specify that the garage is VAT registered and original parts are used to manufacturers spec.
    Im just a bit paranoid nowadays as the belt went on my a3 a couple of weeks ago forcing sale and the purchase of my B7. I had my A3 belt done 30k ago but at the time I had it done in a garage I don't know and I don't know if they used original parts or if the pump was done.
    Can anyone recommend a good indi in South east london or west london?
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Shame as they are a good bunch and like you i don't trust many people. You could email them and ask if they could recommend someone in your area?
    Maybe authorised was the wrong word , i meant a place like i linked , they are all audi/vw trained (2 mechanics used to work for audi ) not just a wrench monkey that works on fiestas or astras all day .
    Ouch about the A3 i had one go many years ago buy i was very lucky and got away with no damage.
    F
    807
    Appreciate your help, seem to have found a good one in clapham (peter norris), mine isnt needed for another 7k or so (73k/3 years old), so I have a while.
    I might even go to Audi just for the cambelt/WPump as "west london audi" is near work and get service done elsewhere.
    Just getting ahead of myself
