EM TuningVolks Autos
Results 1 to 8 of 8
    Oct 2005
    bristol, uk
    671
    TDI models of 100k+ what needs to be considered for maintainance
    e.g. Turbo, Clutch, DPF, EGR Valve, Cambelt, Waterpump etc.
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    292
    hi mate ive owned a couple of vag tdis in the past few years, and the most important thing is to make sure the cambelt change is up to date. the water pump is pretty much universally done at the same time outta ease more then anything.
    as for turbo/clutch i guess thats purely on a car to car basis: ive had a couple of 100k+ motors which have been bang on, pretty much because they've lived most their lives on the motorway.
    one thing i would probably will be doing in the future is taking a laptop with vagcom installed on it to check for any faults etc: with fault codes for crash sensors etc, its damn good to take with you. an older car with no fault codes on it would ring alarm bells for me, as it COULD indicate somebody has cleared the codes to hide something. then again, im a paranoid sort :-)
    good luck!
    danny
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Careful with 2005-2006 2.0 TDI models with the oil balancer shaft.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Oct 2005
    bristol, uk
    671
    thanks
    i had a demo vagcom working before when i had the audi tt 225 with a copy cable, but i would imagine i might need the full thing for crash sensor checks etc.
    but good shout.
    oil balancer shaft, what's that?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    There's a sticky thread about the oil balancer shaft. Basically any 2.0 TDI engines with a code BLB (2005-2006) have an oil pump run by a chain with a plastic tensioner. This plastic is known to fail which can ultimately end up with a new engine. It costs around 2k to swap over before the fault.
    Nathan
    Oct 2005
    bristol, uk
    671
    thanks. yikes 2k to swap part. better off spending the 2k on a newer car!
    Oct 2005
    bristol, uk
    671
    Quote Originally Posted by Wrath View Post
    i assume this would apply to all VAG 2.0tdi 2005-2006 2.0 TDI?
    i.e. like this passat?
    Volkswagen : 2.0 tdi sport estate, 170bhp, big SAT-NAV,FSH,VGC
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Quote Originally Posted by p1tse View Post
    The actual fault affects US Passats, UK A4's and A6's. I haven't heard stories of other models being affected.
    Nathan
