Volks AutosChris Nott
    Jul 2010
    99
    Help please ! All power to drivers door gone ?
    I don't know why but when I got home last nite the remote key fob only locked all doors and boot but not drivers door. It's never happend before. I checked this morning and found there's no power to any switches on the drivers door at all. Any idears . Cheers
    27,126
    Are there any lights on the rear of the door or underneath, if nothing then check the loom in the door rubber to see if its got a broken wire, it connects between the pillar & the door.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    as above very common
    pull rubber boot back theres prob a few wires broke
    usalt the brown and red
    sometimes they dont look broke tug at them you have to look close
    iv done at least 30 this past year with that problem
    Jul 2010
    99
    No lights on any switches etc at all no power to window either or mirror? Haven't checked door loom yet
    bez101's Avatar
    Jul 2008
    8,534
    Quote Originally Posted by fozworth View Post
    its defo the door harness
    27,126
    Yeah not allot more can cause that, I'd check there 1st, if no issues I'd get a meter on the wires to see if any power is getting to the door at all, if not then work backwards & also check any fuses.
