Badger5Monster Motorsport
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    Just bled the brake fluid and replaced...Brake warning lights!!
    Hi there!
    As stated above, I have just replaced all the brake fluid in my car with new fluid and once i started the car the RED brake warning lights come on and don't turn off. I've tried getting the cars ABS to kick in to perhaps fix it, and whilst it does kick in, the brake warning light doesen't turn off! this includes the handbrake warning light.
    Anything i've done wrong or need to do? I've disconnected the battery for now, hoping this might fix it but not sure.
    I bled all the old fluid from the calipers using a extractor machine thingy (thanks to my college garage)
    and at the same time it was pressurising the brake fluid container with new fluid.
    Any comments welcome.
    Thanks in advance,
    Fahim.
    Things to do: Lower on coilovers, spacers, front end respray and a full correctional detail!
    hoban81's Avatar
    Sep 2010
    Manchester
    86
    Did you bleed the master cylinder
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    I think so?
    The machine pressurised the master cylinder with a constant amount of new brake fluid, and so displaced the old fluid through the brake lines and into the calipers. Then i just opened the nipple and allowed all the brake fluid to be emptied out into a bottle untill a constant stream of new brake fluid was going through with no air bubbles.
    Thanks for the quick reply.
    hoban81's Avatar
    Sep 2010
    Manchester
    86
    Ok I did mine a few weeks a go and had weak brakes they worked but there was no pressure in the brake when i pushed it had no warning lights. so I have heard that they may be weight sensers on the wheels so I bleed my brakes the second time while the car was not jacked up did the master cylinder all good.
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    As far as i'm aware, there isn't any weight sensors within the wheel.
    I've found out, thanks to the lovely guys at AMD TECKNIK in West Thurrock that one of my sensors was damaged by the caliper when my disks were fitted and it finally broke i think and thats why it came on.
    I need a new wire or solder the original wire.
    thanks for your input non the less,
    Fahim.
    hoban81's Avatar
    Sep 2010
    Manchester
    86
    Glad you have sorted it, it's sometimes worse not knowing what the problem is.
