Chris NottSky Insurance
Results 1 to 8 of 8
Thread: Wheel Offset
    Jun 2010
    South Wales
    69
    Wheel Offset
    Would the alloys from a 2009 A4 with an offset of 47 still fit on a 2006 A4 without any rubbing issues. The car is an SE with standard suspension.
    Steve
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,673
    They might be a bit tight. I've just swapped my standard wheels with a 42mm offset for a set that are 45mm. There's no rubbing on the suspension uprights, but the gap between the inside of the wheels spokes and the outside of the brake calipers is minimal.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    47 offset will mean the wheel's will sit in more and. The wheel's will look lost inside the arches.
    AUDI A4 190T S-LINE.
    Jul 2010
    Kent
    175
    spacers may be the answer...
    Four Sprung Ducks
    Avant4me's Avatar
    The're Graphite not black!!
    Mar 2010
    Bristol
    257
    I am confussed now. Was looking up offsets on the internet and it is stated that its the difference between the hub face and the middle of the width of the wheel. So wouldn't a lower offset mean that the wheels sit further in??, not a larger one??
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    No the lower the offset number's ie 43 down to 35 will mean that the wheel will sit/poke out more.
    Jul 2010
    Kent
    175
    It's even possible to run negative offset lol....
    Four Sprung Ducks
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    anything between ET43 and ET54 should be fine... some people run ET35, but those stick out so far that you're verging on it being illegal (rims sticking proud of the top of the arch).
    LostBok/BahnStormer77
