Volks AutosJMB Retrofits
    Sep 2010
    37
    K04 Turbo for engine code BEB
    I just found a seller selling a k04 for 1996-2003 1.8t. Don't all k04 turbos fit the 1.8t engine anyway? they said the later version had a bigger flange, so might not fit, the seller is offering a very cheap price and warrantee on it, so quite tempted.
    the description was:
    Compressor
    Inducer: 37.5mm
    Exducer: 50mm
    Trim: .56
    Exhaust:
    Inducer: 46mm
    Exducer: 42mm
    Trim: 83
    Bearing: Journal Bearing
    Downpipe flange type : Audi/VW 1.8 T3 Bolt Standard
    Cooling type: Water and Oil cool
    Audi A4 Cabriolet 1.8T MY06.
    Plate number: 88MU88 (New Zealand) Mu is my last name and yes I am a Chinese.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    There are a LOT of cheap knockoff chinese chocolate-spec turbos floating about, so i'd be very wary of a cheap new K04.
    There are two styles of K04 used on Audis, one fits the transverse engines in the A3/TT/Golf etc, and the other type fits the Longitudinal engines in the A4/A6/Passat etc. They are not interchangeable, so you should ensure its a longitudinal turbo before buying.
    The Fakes usually dont have the proper KKK/Borg Warner markings on them.
    TD5 Land Rover Defender build
