Chris NottMonster Motorsport
    Oct 2010
    32
    Is my DPF knackered??
    Hi folks,
    Well i've had my 07 A4 2.0TDI 170 for a little over 2 weeks now and the problems still keep coming, Last night the engine management light came on and my vagcom came up with the following codes so i think my DPF is about to expire.
    Monday,01,November,2010,16:38:28:26499
    VCDS Version: Release 10.6.1
    Address 01: Engine Labels:
    Control Module Part Number:
    Component and/or Version:
    Software Coding:
    Work Shop Code:
    VCID: 55AA35EB8573
    3 Faults Found:
    001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal
    P0471 - 006 - Short to Plus - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 13
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 136.0 Nm
    Speed: 5.0 km/h
    Pressure: 0.0 mbar
    Text: 21 mbar
    Text: 272 C
    Temperature: 3.0°C
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 12
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 12.0 km/h
    Pressure: 0.0 mbar
    Text: 136 C
    Text: 0 mbar
    Temperature: 1.5°C
    009299 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal
    P2453 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 5.0 km/h
    Pressure: 0.0 mbar
    Text: 0 mbar
    Text: 272 C
    Temperature: 3.0°C
    What do you guys think?.
    Oct 2010
    From what I know that G450 must be replaced. I read that many 2.0 170 owners changed this sensor. What's the mileage of your vehicle?
    Oct 2010
    32
    My car is on 36k miles, Its in the Audi dealership now so we'll see what they say about it.
    jfarhead's Avatar
    176
    Was it the sensor in the end?
    Report to VOSA:
    www.dft.gov.uk/vosa/onlineservices/vehicledefects.htm
    You are covered by the Sale of Goods Act 1979:
    • Goods must "conform to contract", without an error in manufacturing where a faulty component was inserted
    • The seller is responsible for up to six years after purchase
    Facebook:
    • http://www.facebook.com/pages/Fix-th...56033921135623
