Volks AutosSky Insurance
Results 1 to 16 of 16
    unikarl's Avatar
    Mar 2004
    374
    Auto dimming Mirror conversion
    Has anyone converted their standard rear view mirror to an autodimming version?
    I have two autodimming mirrors, both VW/Audi items but neither will attatch to the standard mount that my car has. I can easily work out the wiring but I just wondered if anyone knows if there are any that will directly attach.
    I've noticed Hazzy Days do them as a retro fit so I'm assuming they just use a direct replacement.. Anyone know for sure?
    Karl
    2.0 TDI S line.
    Cruise, Leather, DIS, RNS-E, autodim, MFSW, ambient lights, Bi xenons.
    Gone to its new home
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    I'm interested in this but you need a new windscreen that has the auto-dimming mount. You might find a scratch on your windscreen that requires it to be changed under insurance....hint, hint.
    Be nice to know if you accomplish this as I have only seen instructions for wiring from an A6.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,317
    I retro-fitted one of these. It works perfectly. It's exactly the same part that manufacturers fit OEM; you just don't get the fancy plastic moulding around it. It comes with an adapter to fit it onto the car's existing button mount.
    I fitted one to my B6 a few years ago, and have just swapped it onto my new B7 a few days ago.
    Save yourself an absolute fortune.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,317
    Quote Originally Posted by unikarl View Post
    Karl
    If all you need is the adapter, try this.
    unikarl's Avatar
    Mar 2004
    374
    I've ordered one. Hopefully I'll have that fitted before the weekend. Have a thanks!!
    2.0 TDI S line.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Please post pics of your install.
    Nathan
    unikarl's Avatar
    Mar 2004
    374
    Will do. I paid for special delivery so I might have it tomorrow.
    2.0 TDI S line.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,317
    Quote Originally Posted by Wrath View Post
    Here are pics from the installation in my B6. The cable runs along the top of the headlining, down the driver's door pillar trim and behind the end of the dash to the fuse box. By tilting open the mini-visor in the centre, I obscured the inch or so of exposed cable from my eye-line. On the outside, it was concealed by the dark band at the top of the windscreen.
    The B7 install is identical, except there is no dark band, so it is a bit visible on the outside. A trip to my window tinter will take care of that, though.
    In terms of cost, ease of installation and benefit gained, this is one of my favourtie mods ever.
    View from driver's seat.
    Inside view from side
    Outside view
    unikarl's Avatar
    Mar 2004
    374
    Well its in!
    What a nightmare of a job though. I had to use the new adapter I got off ebay and attach it to the existing mount from the autodimming mirror. All in its taken me about 2 hours but knowing what to do now I think I could half that install time.
    This is still version 1 of my install... Version 2 will have the wire cover "potted" in with black resin to hide the insides and give a more oem look.
    Pictures.....
    2.0 TDI S line.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,317
    Nice result
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Did you use the OEM cover to hide the wire?
    Nathan
    unikarl's Avatar
    Mar 2004
    374
    Yes I did. The miror I bought came with the cover. I put some black heat shrink over the wire to neaten it up until I can get it properly hiden.
    2.0 TDI S line.
    26,750
    Thats why the band & oem fitment is better imho, looks much nicer when fitted as per oem to the outside world, but good job regardless & nice find that adapter, cant stand the trailing wire though on a pic higher up, just looks, well no offense tacky in a nice car, but I appreciate changing screen etc can be a pita overall.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,317
    T cant stand the trailing wire though on a pic higher up, just looks, well no offense tacky in a nice car, but I appreciate changing screen etc can be a pita overall.
    But you can't see the trailing wire when you fold down the mini visor.
    26,750
    Then I wont be able to see the sunsets through that gap :P
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,317
    Thank gawd this is Britain and the sun never shines.
