EM TuningSky Insurance
Thread: HEAVY STEERING
    Flat Out
    Apr 2007
    Essex
    144
    HEAVY STEERING
    Does anyone else suffer with this problem? Wifes A4 Cab 2007 model is like a tank to drive, feels like only half the power steering is working. Tyre pressures are all correct. Is it the rack on the way out perhaps? Car has done 30000 miles. Thanks in advance for any answers.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Have you checked the fluid level in the power steering reservoir?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Flat Out
    Apr 2007
    Essex
    144
    Yes, checked that and it is between half and full with engine running. Not sure where it is meant to be though.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Quote Originally Posted by RallyX View Post
    There's a dipstick built into the screw-on cap. Also, I don't think you're supposed to check it when the engine is running.
    Sep 2010
    19
    I have a similar problem on my B6 S4, it appears my servotronic solenoid is knackered, but only available with steering rack, 750 parts only!
