Chris NottBadger5
    Bigman's Avatar
    Cornish and Proud!
    Mar 2007
    Nuneaton, Warwickshire
    85
    2.0TFSI oil cooler failure??
    Hey guys
    Had abit of a look at the coolant the other day and it seamed abit oily, initialy I thought it might be the head gasket, which would not be a good thing, but the temperature doesn't seem to be soaring as I would expect it to if it was gone. I have heard about people having leaking oil coolers, has anyone had this happen before?
    My plan is to give the cooling system a flush and stick in some new coolant to see what happens.
    Adam
    Adam 'Bigman' Phillips
    Audi A4 B7 2.0TFSI S-Line Avant, Red!
    Debadged rear, Full DIS, Cruise, B5 A4 front lower spring seats (15mm lower than B7), XCarlink, RS4 RARB, Factory Fitted BOSE, 2 tone leather interior.
    Future Mods: R-Tech Re-map, H&R Springs, 15mm rear and 12mm front wheel spacers.
    North East
    607
    I had the very same symptoms on a B5 1.6 ( many years ago) and it was the oilcooler that failed.The G12 coolant in the expansion bottle turned into a very thick brown emulsified oil .
